18" wheels & Konis.
18" wheels & Konis.
Has anyone else had an issue with running 18" alloys with an offset of ET25 with a koni suspension kit ? Since fitting mine I've found that the wheels foul the Spring cups & even with gentle persuasion with a large hammer they still won't fit correctly.
Has anyone elses come across this & how did you get around it.
Thanks for any help.
Caraholic
What tyres are you running?
Even with 225/40s you have to do this to the spring cups:
If you're running bigger tyres, then I don't think you will get them to fit. This is why we run ET15 offset....
I caren't believe Koni caren't get this right from the factory.You'd expect Et25 downwards would fit without fouling.
i have 18s , same size tyres , same ofset , and konis ive got spacers on that are bolted to the hub this spacer has its own wheel nuts and enough hub lip , they came with the car when i bought it ,so unsure who supplies them ,but this setup works a treat ,someone must sell them
i have 18s , same size tyres , same ofset , and konis ive got spacers on that are bolted to the hub this spacer has its own wheel nuts and hub lip , they came with the car when i bought it ,so unsure who supplies them ,but this setup works a treat ,someone must sell them
Thanks for the advice.
Caraholic
E-mail Address(es): CARNOISSEURSOUTH@aol.com
Chris (AKA Cossymad) at Carnoisseaur can do these at a very good price .
Spoke with Chris & he can sort me out with the spacers I need, top man ! Thanks for everyones help, i'd of been gutted if I had to sell the wheels.
does this problem only happen with 18" wheels and konis? I was going to go for 17" wheels but have just been offered a set of 18" OZ Super Ts.
Adam Graham
06-09-2015 06:04 AM
