flank thickness standard brakedisks
Old 09-04-2008, 04:21 PM
Spotmatic
Spotmatic's Avatar
Exclamation flank thickness standard brakedisks
Hello,
I need to know the flank thickness of the standard front brakedisks. By the flank i do mean the part witch attatches to the wheelhubs. I can't mesure it myself as i've sold my front brakesetup.
Thank you in advance,
Mark
Old 10-04-2008, 04:11 PM
Spotmatic
Spotmatic's Avatar
Does nobody have a set standard brakedisks laying around? I need this size to calculate the correct size of wheelspacers i would like to buy today. I currently have Godspeed brakedisks with a flank thickness of 15mm
Old 11-04-2008, 10:23 AM
Spotmatic
Spotmatic's Avatar
I've bought an AP Racing BBK from Godspeed, the diskflanks of these disks are 15mm thick. This means i will need to buy different wheelspacers for my Group A (ET33) wheels. The original brakesetup has already been sold. So if someone can mesure this for my i can order the correct wheelspacers.
Thank you!
Old 12-04-2008, 10:46 AM
Spotmatic
Spotmatic's Avatar
Nobody?
Old 14-04-2008, 02:15 PM
dojj
Resident Wrestling Legend
dojj's Avatar
15mm ?!?!?!?!?!?!?!
they should only be about 8mm thick from what i can remember mate, possible even thinner than that
your wheels are going to be MILES out
Old 14-04-2008, 02:38 PM
Dave Henshall
Dave Henshall's Avatar
this site has a LOT of useful info......
http://www.national-auto.co.uk/catafiles/brake/nbd.pdf
Old 14-04-2008, 06:57 PM
Spotmatic
Spotmatic's Avatar
Originally Posted by dojj
15mm ?!?!?!?!?!?!?!
Yes they are, in my case not a problem as i run group A (ET33) wheels. The problem is that i don't know witch wheelspacers to use to get to ET15-ET18.
Thank you! Pity that the size needed is not quoted.
Old 16-04-2008, 07:52 AM
Spotmatic
Spotmatic's Avatar
No one?
Old 17-04-2008, 06:49 PM
Spotmatic
Spotmatic's Avatar
Unhappy
Really desperate to find this out.....
Old 18-04-2008, 08:52 AM
NUTS RuS
NUTS RuS's Avatar
I will measure it today if you still need the info
Old 18-04-2008, 10:48 AM
Spotmatic
Spotmatic's Avatar
That would make me very happy indeed! Thanks!
Old 18-04-2008, 11:18 AM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
If you're saying you have spacers built in to the bells of 15mm, that is perfect to achieve the offset that you want with ET33 wheels. The higher the number, the more INSET the wheels are, so if you have 15mm spacers, then this would make the wheel offset equivalent to ET18 (subtract the spacer width from the wheel ET to get the new ET), which depending on the width of the wheels, is perfectly adequate (unless of course the car is already a wide-track Grp A car, which is what the ET33 wheels were designed for) .
So in answer to your question, another set of 15mm spacers should do the trick, but you will need these front and rear. Eibach do some this thick and Cossymad off the BB can supply them if you can' get them in your country.
Old 18-04-2008, 11:24 AM
Spotmatic
Spotmatic's Avatar
Thanks for your reply, i'm not saying that the bells have 15mm spacers but the bells are 14.5 mm thick. Thats why i need to know the size of the standard disks to calculate what spacers i do need.
Mark
Old 18-04-2008, 11:31 AM
Mike Rainbird
Caraholic
To achieve the correct offset that you want with "normal" thickness bells, you need 15mm spacers .
Old 18-04-2008, 11:39 AM
NUTS RuS
NUTS RuS's Avatar
Flank thickness on the ones I have here is 8mm
Old 18-04-2008, 12:15 PM
Spotmatic
Spotmatic's Avatar
Thumbs up
Thank you! This means i will have to buy 10mm spacers at the front and 15mm at the back! thank you very much!!!
Old 18-04-2008, 12:23 PM
Spotmatic
Spotmatic's Avatar
Mike, how thick are the original AP bells?
Old 18-04-2008, 12:24 PM
NUTS RuS
NUTS RuS's Avatar
No problem
07-10-2015 12:56 PM
XR4
Ford XR Range
01-10-2015 12:46 PM
PRO-LINE MOTORSPORT
28-09-2015 09:54 PM
SMILER258
28-09-2015 09:04 AM
Quick Reply: flank thickness standard brakedisks
