seirra 4x4 rear diff
Mark the input shaft, mark the output shafts. Turn the input 3.9 times, and the outputs shafts should only rotate once, should be able to see the differance between 3.6 turns of the input and 3.9. The messy way is to take the rear cover off and count the teeth on the crownwheel and count the teeth on the pinion, divide the crownwheel number by the pinion number and that should give you your ratio
In Development
Hi,
A friendly man at the local ford dealer let me use his microfiche machine and I've managed to get all the part numbers, FINIS numbers, exploded diagrams etc for Sierra, Granada and Scorpios. I'm putting together everything I've found at www.super7thheaven.co.uk
Hope that helps - It's a work in progress
155lee
14-09-2015 07:37 PM
xr4x4rs
06-08-2015 09:03 PM
