prop fouling on exhaust ...HELP...
Hi Guys Just Fitted My Engine Into My Car And When I Connected The Front Prop I Noticed The Large Knuckle Type Joint At The Front Catches On The Exhaust Which Is Bolted Up And Is On Its Rubbers Correctly Any Help Very Much Appreciated.
I had this too a short while back and it only stopped after the turbo bolts were mega tighted as they kept working slightly loose.
Has been fine since...
Poly exhuast hanger busges help too.
Russ Payne
25-09-2015 08:29 PM
