best chip for 803's
best chip for 803's
hi there , does anyone knows who does the best chip for escort cosworth t34 wth 803's, and what is the highest figure you can get with them !
many thanks
many thanks
Post Miester !
Get a Closed Loop Chip From Motorsport Delevopments !
Mine Made 360 BHP at 25 PSI Only real engine mod is a ported head, so yours should be around 340 BHP imo.
Easy to install and setup..
I think nearly all chips for greens are mostly the same.
The advantage from Motorsport Developments might be that the original boost solenoid can be used
Normaly, every chip must use it.
The GGR uses the standard 2.5bar Map sensor, and you have to recalibrate the waste gate.
For my car, as my solenoid's dead, I'll use a bigger collin's 31 WG with a bleed valve to regulate around 1.3bar (looking for reliability )
wheelwizardrefurbs
18-09-2015 08:59 PM
