Witch alignment for a fast road Escos
Old 28-02-2008, 02:57 PM
Spotmatic
Spotmatic's Avatar
Default Witch alignment for a fast road Escos
Hello,
I have fitted new brakes and new wheels to my Escos, Now it's time to get the car aligned correct.
The car is used for fast road (curved roads) driving in the weekends and once in the month for a trip to (and ofcourse ON) the Nordschleife. It's not a daily driver.
The suspention still is original and will stay original for a while. The wheels are 18" and the brakes come from AP.
What camber, caster, toe-in/ toe-out do you advise?
Regards,
Mark
Old 28-02-2008, 04:13 PM
Dave Henshall
Dave Henshall's Avatar
only ajustment on a facotory setup is front toe.
set to toing in 1mm overall (0.5 each side) - as the bushes flex under aceleration they deflect to 0 (assuming they are ok and not fooked) which will give a nice neatral feel thet wont tramline too much - like if you set it at 0 to start with as the deflection when accelerating casues it to toe out and pull when you get on white lines etc
Old 29-02-2008, 08:45 PM
ECOS95
ECOS95's Avatar
As Dave has said 0.5mm toe in, had mine set to this & it does feel much better.
Old 01-03-2008, 06:58 PM
Spotmatic
Spotmatic's Avatar
Okay, thanks. I will try so.
gambo08
04-02-2016 10:49 PM
gcfcos
59
06-10-2015 05:04 PM
mk22door
23
02-10-2015 10:06 PM
Kiran1600E
11
02-10-2015 11:35 AM
AJC
01-10-2015 06:47 PM
Quick Reply: Witch alignment for a fast road Escos
