magnex no longer available?
Old 13-02-2008, 04:44 PM
stookay
stookay's Avatar
Default magnex no longer available?
tried to get magnex full system today , woodford said they not making them anymore , tried magnex website and it not even listed , who else sells them?
Old 13-02-2008, 05:30 PM
AJC
AJC's Avatar
why magnex inparticular?
mongoose better in my opinion
Old 13-02-2008, 06:15 PM
stookay
stookay's Avatar
see my thread "magnex v mongoose" in this section , i just heard they were a better fit , more ground clearance etc . so put up post for a few opinions .
Old 13-02-2008, 07:22 PM
Dan@Rapid-Ford
Dan@Rapid-Ford's Avatar
I know somebody that is selling one in VGC if your interested??
Old 14-02-2008, 11:35 AM
cosworth3d
cosworth3d's Avatar
better ground clearance they fit as the original system i want one for mine as well so magnex peeps if your reading this 2 been sold allready
Old 14-02-2008, 12:13 PM
R5COS
R5COS's Avatar
get a mongoose
Old 14-02-2008, 12:19 PM
Dave Henshall
Dave Henshall's Avatar
the mongoose only founls the front prop/chassis leg if not fitted correclt inthe first place,
had a mongoose on my saph 4x4 and my escos, very pleased with both.
i'm now in a dilema over one for the ST, as i was gonna go for mongoose again, BUT the magnex for owner members on focusstoc.com is a very good price.
Old 14-02-2008, 01:21 PM
cossymad
cossymad's Avatar
The Magnex was discontinued about 4 Years ago, but we were able to get Magnex to make them made in batches of 10, which we did. It may be possible to get them to do this again.
Unfortunately the call for these has declined, as more and more people who have Escort Cossies have already got stainlesses that last forever.
The magnex is a twin (side by side) system that is a little quieter than the Mongoose, which on big BHP means you are more likely to pass sound test at a track day. The magnex one is very similar to the original, splitting in 2 after the down pipe. It fits alot closer to the bottom of the car as it uses 2 small pipes rather than one big one.
Old 14-02-2008, 04:25 PM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
The Magnex also offers slightly improve flow than the Mongoose, as it is a twin 2ź" system, which has greater flow than a single 3" system.
As to it be quieter, it only has a twin silencer arrangement like the Mongoose, but because these are situated where the OE ones are, you can actually fit a back box as well (which is what I did to mine).
Old 14-02-2008, 04:32 PM
Rippers
Monte Geek
Rippers's Avatar
Mike on the subject of Magnex's, Harvey said when fitting the 6degree beam some magnex's hit and other don't. I know yours did, but how old was your magnex? I know mine I bought from you was one of the newer batches with the smaller tail pipe so wondered if that may have been different? ie whether it was just completely random that they hit or whether it was a when it was made was the difference?
I guess I'll find out soon enough
Old 14-02-2008, 04:36 PM
cossymad
cossymad's Avatar
Mines been fine, had it on for 6 years, and I prefer it to the Mongoose on my other one.
Old 14-02-2008, 09:02 PM
rapidcossie
rapidcossie's Avatar
you still on a standard exhaust Stoo?
Old 15-02-2008, 09:34 AM
Mike Rainbird
Caraholic
All the Magnex exhausts hit with a 6° rear beam and have to have the mounting brackets repositioned to clear.
Old 15-02-2008, 10:19 AM
Rippers
Monte Geek
Rippers's Avatar
Do you have a pic of the mod needed Mike?
Old 15-02-2008, 12:18 PM
Mike Rainbird
Caraholic
The brackets near to the back boxes just have to be cut off and re-welded in place to clear the inner arm joints (which they foul against as standard).
Old 15-02-2008, 04:48 PM
stookay
stookay's Avatar
hi euan , no i thought i had scorpion on it , turns out its mongoose , but centre box pretty bashed in , hangers corroded etc , would of liked a magnex , ive got new mongoose sitting here although IMO its quite poorly made ,if i put welding like that out at ma work ad get paid off .
Old 17-02-2008, 09:50 PM
Gez500
Gez500's Avatar
Default Magnex
COSSYMAD, could you please find out if Magnex would make up a batch if you got the required number together?
Cheers, Gez
Old 18-02-2008, 07:43 AM
cossymad
cossymad's Avatar
OK I will.
Old 18-02-2008, 01:09 PM
cossymad
cossymad's Avatar
OK I spoke to Magnex, who said they would be able to do me 10 systems although I did have to beg them
If I could get enough interested I will be able to do them at the price we used to sell them at aswell.
RRP on these systems is Ł684.75 + postage !!!
I could sell them to peeps on here for Ł515 + postage (25% off)
I can deliver pretty much anywhere, but price needs to be confirmed on the postage to each destination
Old 18-02-2008, 01:54 PM
Rippers
Monte Geek
Rippers's Avatar
Thats not bad actually
I wonder if they will do them with the large old shaped tailpipe instead of the small oval they made that last batch with?
Old 18-02-2008, 01:56 PM
cossymad
cossymad's Avatar
Bigger is better right?
Old 18-02-2008, 02:07 PM
Rippers
Monte Geek
Rippers's Avatar
Oh yes, it was the tailpipe that made me want it
Old 18-02-2008, 07:10 PM
stookay
stookay's Avatar
fitted that mongoose today , the things a disgrace in my opinion, the front section when bolted to turbo , makes the rest of the system about 25mm to long , the two chaps that put it on said it one o the worst fiiting exhausts they've seen , contrast this with the magnex they put on the my rs 2000 in about 15 mins . theyve actually said i should just send it back but it been fitted and i didnt think theyd have accepted it back, al be ditching it when the magnex arrives i just hope magnex maintain there quality on a low volume production run. ok rant over
Old 19-02-2008, 11:10 AM
Dave Henshall
strange that, as i fitted my mongoose on my own with just a set of ramps in around half an hour, perfect fit.
Old 19-02-2008, 01:01 PM
CossieGirl
Miss Doubtsalot
CossieGirl's Avatar
I want one!
Old 19-02-2008, 01:09 PM
cossymad
cossymad's Avatar
1. Cossiegirl
9 to go!!!
Old 22-02-2008, 05:09 PM
Gez500
Gez500's Avatar
Default Magnex
Hello mate,
Would they do a Cat back version for the T25 Small Turbo Esc Cos, with the smaller oval tail pipe?
Thanks for making the enquiry to Magnex.
Cheers, Gez
DavidK
27-09-2015 02:55 PM
TC-ST3
26-09-2015 04:47 PM
Ridgey
13-09-2015 08:43 PM
mike elsome
Ford Range
09-09-2015 05:05 PM
Quick Reply: magnex no longer available?
