coil packs
coil packs
Just a quick question please, was thinking about going to coil packs on my escort, was speaking about this with someone. They weren't sure, but thought cossie's running coil packs, the rev counters don't work. Is this the case?
Thanks
Thanks
Originally Posted by vinnya77
Thanks, do they run coil packs then standard?
RS2000 yes.
look like this
http://cgi.ebay.co.uk/Ford-escort-rs...QQcmdZViewItem
Literally change the working parts behind the rev counter.
Note what rpm your car idles on before changing and then after, reset the needle with the front face of the clocks off ( clear plastic bit) and the engine running
You need to run a feed to the green wire from the rev counter, to ONE of the OUTSIDE (neg) wires on the new coilpack plug (3 wires).
Any probs I have pics of what to do. (on a Big turbo escos!!)
Originally Posted by Rolls
Originally Posted by PewteRS
All i did with mine was solder a wire in the back of the rev counter............the instructions off Stu were easy to follow.
Yeah - mine is really odd
the rev-counter used to read half once the coipack conversion was fitted to mine.. - fitted an rs2k revcounter, and now it seems to read double? And my rev-counter on the sec monitor deosn't work at all
Bloody cars
Bloody cars
1 Post
is yours one of the early secs driver boards? my 1st one read half even after doing the wiring mod,
your rs2k rev counter should work if you are picking up the earth of 1 of the coils as that is exactly how it picks up on the rs2K. i suspect you are using the feed from the secs board onto your new rev counter....?
1 Post
how exactly is the loom configured, to pick up one side of one of the coils to drive the tacho = should be if you are running the rs2K tacho, or from the pin at the ecu as per std install using original tacho via the original wiring at the coil back to the tacho?
an easy test would be to hold the car at around 3K revs, and get someont to disconnect the multiplug from the coilpack. if the rev counter drops to 0 immediately that the wiring is correct. if it drops down matching the engine speed as the engine stops to 0 then its wired as a std car using the driver board to supply the rev counter feed.
07-10-2015 12:56 PM
