AP 362 brake kit...
Old 22-01-2008, 05:19 PM
jens henrik vinther
jens henrik vinther's Avatar
Default AP 362 brake kit...
Hi guys.
I hope that some of you can help me . I have just fitted a 362 AP brake kit to my escos and my wheels are the AZEV type A 8,5x18 ET18, I was told when i bougt the brake kit that they would fit right on my car, but they dont, they are 14mm off. Now my question: Does there exist any kind of spacers and longer studs that are any good, so the driveabillity is not compromiced? 14mm is a huge spacer, or not???
Please help me
Jens henrik vinther (denmark)
Old 22-01-2008, 05:46 PM
G1EN
G1EN's Avatar
The best possible spacer would be HUBCENTRIC, they do solid cast spacers with all the trimmings, such as longer stud etc etc.
http://www.srbpower.com/hr/spacers.php
Old 22-01-2008, 05:52 PM
AJC
AJC's Avatar
i have a set of 4 hubcentric spacers, made by eibach
they are for sale if you interested?
25mm thick
Old 22-01-2008, 06:35 PM
jens henrik vinther
25mm thick
Hi Andy. Thanks but thats a little to wide.
Old 22-01-2008, 07:13 PM
JanDK
JanDK's Avatar
Oops hva Jens.. Den var da en kedeligt oplevelse Det er godt nok osse et fyldigt bremsekit.
Har du rykket bremsekittet af igen sĺ, eller havde du andre hjul at montere??
Old 23-01-2008, 03:57 PM
jens henrik vinther
Hej Jan.
nej bilen křre ikke om vinteren, men jeg skal da have fundet en lřsning pĺ problemet, hvis de kloge hoveder ikke mener at jeg skal křre med 20MM spacers i, jamen sĺ er jeg jo nřd til at ja mĺske křbe nogle nye fćlge. Men det ville jo vćre rigtig ćrgeligt for det er jo de fćlge jeg vil have ogsĺ er de kun knap et halv ĺr gamle. Hvis du evt kender en der er interesseret sĺ mĺ du endelig sige til .
MVH.
jens henrik vinther
Old 23-01-2008, 04:20 PM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
What offset are the AZEVs, as I think you will struggle with arch clearance with 20mm spacers. The AZEVs are rubbish for clearance, and won't even clear 330 4-pots without spacers!
Old 23-01-2008, 05:15 PM
Glenn5
Glenn5's Avatar
we had 356 ap 6pots with cp5555 calipers and avez A et 18 with no issues only moving balance weights close but was fine was a reyland/rainbird kit aswell no spacers whatsoever needed
Old 23-01-2008, 06:54 PM
jens henrik vinther
Mike the ofset is ET18, but my mesure was wrong it is only 14mm on each side. Do you think that the arch clearence will be ok with 14mm spacers??
Old 23-01-2008, 07:59 PM
JanDK
JanDK's Avatar
Hej Jan.
MVH.
jens henrik vinther
Uha... kender kun nogen (som er vilde med den fćlg) som SLET ikke kan presse dem ind under skrćmkanten surt. Og sĺ er jeg MEGET syg med den fćlg.. men er selv ved at křbe store bremser og vil ikke tage chancen hehe.
Der skal nok komme nogle gode rĺd herfra, thats for sure!! Og de er allerede igang og skaber tvivl
Old 24-01-2008, 08:20 AM
Mike Rainbird
Caraholic
I think you will struggle, depending on ride height. To get an idea, why not space the wheel out 14mm with some washers and see where it sits?
Old 24-01-2008, 12:22 PM
Rippers
Monte Geek
Rippers's Avatar
ET18 wheels with a 14mm spacer would make them ET4 can't be good for the bearings?
Old 24-01-2008, 04:02 PM
Martin-Hadland
1st to 200 without NOS
Martin-Hadland's Avatar
14mm spacers on those wheels will not work unless you want to widen the wings You could space everything inwards with new bells and rose jointed track rod ends but you will still be in trouble.
Simple fix.. Change the wheels to the new 8.5" ET18 MO, they will fit then.
muzzman1
30-09-2015 08:59 PM
Sp3no
27-09-2015 07:23 PM
Quick Reply: AP 362 brake kit...
