break pedal gone proper stiff and hence got no breaks help
Old 21-01-2008, 10:44 PM
confused.com
confused.com's Avatar
Default break pedal gone proper stiff and hence got no breaks help
my pedal has gone stiff im not sure if its the servo or the break ecu
Old 21-01-2008, 10:45 PM
confused.com
its an escort cos by the way 92
Old 22-01-2008, 09:52 AM
ECOS95
ECOS95's Avatar
Is the ABS light on ?
Old 22-01-2008, 10:18 AM
mike72168
mike72168's Avatar
When mine did this it was the brake pedal switch, worth checking!
Old 22-01-2008, 12:37 PM
Gavin E-Cos
Gavin E-Cos's Avatar
check just under the brake distribution block. There are some pipes T'ed in that connect to a small cylinder near the MAP sensor.
My pipe had come off and I had waht you discribe.
Just make sure the pipe are connected.
Gav
Old 22-01-2008, 12:44 PM
hughy
hughy's Avatar
m8 check there are no broken wires out at th terminals my brakes went some like that before and it was brken red wire at battery terminal
Old 22-01-2008, 12:56 PM
Gavin E-Cos
not electric cables, vaccum pipes.
Find the cylinder near the MAP sensor, there is a small vaccum pipe that comes off that and goes under the brake block, and T's into what looks like a brake pipe, that heads off towards the brake system.
On mine the pipe from the cylinder had come off at the T junction.
No idea excatly what this does, but as soon as I put it back the ABS pump primed and held pressure and stopped. Before putting this pipe back on the ABS pump would not stop.
Hope this helps, was an easy fix for me, when I found it!
Gav
Old 22-01-2008, 08:41 PM
confused.com
thanks for all your help everyone i think we have found its the fuse box
chowfornow
14
05-01-2019 09:01 PM
155lee
24-10-2015 11:11 AM
07-10-2015 12:56 PM
Quick Reply: break pedal gone proper stiff and hence got no breaks help
