Will 6 pot 310mm Tarox brakes fit under standard wheels?
With the Compbrake 16" set they supply 15mm wheelspacers, without these spacers this set won't fit. I'm quite sure you will need these spacers with this Tarox set too.
Can you tell me what type Tarox calipers you mean? They sell different 6-pot setups.
Regards,
Mark
Regards,
Mark
Regards,
Mark
Regards,
Mark
Richie, I really want these however I am worried about them fitting behind the standard wheels as I absolutely don't want to use spacers
Do you have access to an Escos alloy to see if they do indeed fit
They won't fit standard 16" wheels without spacers. Normally 16" kits also use 305mm rotors. 310mm will be a very tight fit or won't fit at all.
Regards,
Mark
Regards,
Mark
aka Turbosailorboy
Matt,
My old red one had 6 pot Tarrox with i think ( dont quote me ) 308mm discs?
It ran std wheels fine, just a few MM spacer was needed.
I'll see if the missus has any pics??
PS My Wheel weights are inside and outside on the AP 6 pots with 355's!!!
jason_nike
18-08-2019 10:53 AM
track.focus'd
12-08-2015 05:53 PM
