FAO Kelv and YUM - dash light inverter!!
found the thread......
https://passionford.com/forum/viewto...er=asc&start=0
not too hard to do - done it to my old clocks!!
Guest
Posts: n/a
Cool
But i dont have any clocks at all now as l have a AIM dash so how will l wire a inverter in now
anyone know what number/colour of the clocks wires need to to inverter to make the other clocks light up
Also while we are on it anyone wired up there ABS light and what
feed did you use
feed did you use
Originally Posted by MAD YUM
Cool
feed did you use
feed did you use
do you still have the OE plug on the loom??
Guest
Posts: n/a
Originally Posted by kjc300
Yep!!
Right....
ABS = pin 6 & 7
inverter = pin 11 & 13
Right....
ABS = pin 6 & 7
Cool
Does the ABS Light feed need any other wires because im sure l took a feed of them and it did not light up the light
So if l buy the inverter l just need to connect it to 11 and 13? for the other clocks to light up?
Sorry not that great at wiring
Yep!!
Right....
ABS = pin 6 & 7
Right....
ABS = pin 6 & 7
Cool
The abs light should only come on for a bit on ign shouldn't it?
it's not THAT easy for the inverter, I have just looked on the other thread and there may be a resistor involved. I may have to investigate further!!
Guest
Posts: n/a
Yep!!
Right....
ABS = pin 6 & 7
Right....
ABS = pin 6 & 7
Cool
Will have to have another look into it when l get yum back from the body shop
If you could find out about the inverter that would be great
Almost there!
Cheers for that Kev, must admit it doesnt affect me to much as my pectel monitor is fitted in the banana pod.
but looks like its going to help you Dave.
will be selling my complete mint set of clocks and banana pod gauges into the new year
nipper.1
Ford KUGA
12
30-05-2022 07:39 PM
The Enigma
12-09-2015 10:12 PM
