Starting a cossie from cold
Old 11-06-2007, 10:04 AM
psygnosis
psygnosis's Avatar
Default Starting a cossie from cold
Hi pilgrims
Just a quick question when starting a cossie from cold how long should you leave it running before you start driving it as someone said its always good to warm the turbo up and the engine and also when you have been driving it not to just turn the engine off but wait and let the turbo cool down.
Does anyone do this or what do people recommend
Cheers Pilgrims
Old 11-06-2007, 12:07 PM
I do what makes the engine happy, on mine it is about 2 mins warm up otherwise it is fussy, then 1 minute cool down, BUT I always do the last miles or so OFF BOOST to slow turbo down.
Old 11-06-2007, 12:22 PM
cozmeister
More boost Igor!
cozmeister's Avatar
I tend to drive straight off as it warms up quicker than just sitting there idling...and that's what the owners manual says too.
I don't drive it on boost at all until I've been driving around for about 5 minutes or so, and give always it a minute to spool down if it's just been on boost before i turn it off.
Old 11-06-2007, 01:34 PM
RWD_cossie_wil
RWD_cossie_wil's Avatar
Don't leave it sat idling cold, the oil pressure is low and will wear everthing faster, especially followers/cams etc.. Just drive it carefully until it is warm, then kill it
Cooldown, I run mine for the last 2 miles or so off boost, then 30 secs cooldown, no longer as you just heatsoak the engine and turbo
Old 11-06-2007, 04:08 PM
Oil pressure will be higher when cold than hot at idle, and they are total loss in the bearings anyway, with no load it does no harm if you have decent pressure anyway.
Old 12-06-2007, 10:17 PM
Aaroncast
Aaroncast's Avatar
i leave my escort cossy on the drive to warm up same as my other cars (diesels etc) never have or expecting problems-same goes for garaging after a run (cossy only) let it run for a few minutes after driving home on no boost for the last mile or so-never believed in starting a car and booting it !!!-go on try it!! jump out of bed and straight out the door for a four mile run-ha-ha
carlo
24
05-10-2015 08:20 PM
Adam-M
26-08-2015 05:53 PM
The Enigma
13
20-08-2015 09:38 PM
Archiejay
12-08-2015 12:07 PM
CabrioTurbo
01-08-2015 11:04 AM
Quick Reply: Starting a cossie from cold
