2wd rear beam + diff on a 4wd car
Old 09-06-2007, 02:22 PM
MTZ1
MTZ1's Avatar
Default 2wd rear beam + diff on a 4wd car
What do I need to fit a 2wd rear beem to an escort cosworth? --> does it work with the std. prop shaft?
I've a complete 2wd rear axle here and i'm thinking about upgrading my escort...
Old 09-06-2007, 08:57 PM
The DIVA
The DIVA's Avatar
Will fit straight on mate,the diff ratio is very slightly different at 3.64:1(4x4 is 3.62:1) but will not cause any problem........
Shafts and joints are a lot stronger in 2wd kit,so is a very good conversion..
Old 10-06-2007, 08:58 AM
MTZ1
MTZ1's Avatar
good news!
thanks!
Old 10-06-2007, 02:20 PM
MTZ1
MTZ1's Avatar
oh... i've forgotten something... i have some 3.92diffs here (2.0 sierra 4x4) -> is there a way to use the 3.92 gear in the 7.5" diff?
Old 10-06-2007, 04:08 PM
dojj
Resident Wrestling Legend
dojj's Avatar
it is almost certainly a 7 inch diff you've got there so you will not be able to use it in the 7.5 inch casing as it's all wrong
what you might be able to do it use the output flanges from the 7.5 inch in the 3.92 diff and then just use a small spacer to bolt up the diff to the beam (which works all the time)
Old 10-06-2007, 04:46 PM
Kelv
Almost there!
Kelv's Avatar
But surely thats alot of hard work fitting the 2wd rear beam just to still use the smaller 4x4 7" diff!
all that swapping and changing of the beam and output flanges etc, and then still using the 4x4 diff which is now mounted with spacers! the only real benefit after all that work is stronger flanges and driveshafts, when all it see's is 60% of the power anyway!
Old 10-06-2007, 06:24 PM
MTZ1
MTZ1's Avatar
i'm using a GT30R + 2,4L crank... so i need a quite good drivetrain... -> have a strait cut gearbox + "thin" front prop shaft (I think it's a group a item) + a "weldet" front dif --> more or less like a thick wall diff... lot af aluminium weldet on...
xr4x4rs
06-08-2015 09:03 PM
COLEYST200
03-08-2015 08:55 AM
lockie
31-07-2015 10:03 PM
Quick Reply: 2wd rear beam + diff on a 4wd car
