Replacing Escort rear windows
Old 04-06-2007, 10:02 AM
JanDK
JanDK's Avatar
Default Replacing Escort rear windows
Have anyone in here done this???
Is it still a proper EscCos if I do it??? I am just really tired of rusty caps/nut.
Old 04-06-2007, 12:51 PM
- Sim -
- Sim -'s Avatar
no but i want to put plastic glued ones in, as I never will use my normal windows with the rear seats removed
Old 04-06-2007, 01:47 PM
JanDK
JanDK's Avatar
that is correct Sim... Is it totally stripped??
I read somewhere resently that Escort 3dr rears fit straight over without needing anything .. beside the window and seal ofcause.
Old 04-06-2007, 03:56 PM
The Youth.
The Youth.'s Avatar
the caps are pennies from ford just change them I did mine 4 years ago and there still fine now
steve
Old 05-06-2007, 06:37 AM
JanDK
JanDK's Avatar
Steve
yes Steve.. I know and so are the grommets in the window, og dead easy to change, but I am not happy with the rusty water down the window, and comes back even when I brush the nuts before refit the caps. Now I think of doing the replacement cause it should be sp easy... fit and forget
Thanks
Old 05-06-2007, 08:25 AM
- Sim -
- Sim -'s Avatar
my car?
yes everything taken out, all damping material and so on as well.
yes the normal 3 rd escort rear windows will fit, as well as the complete doors.
I m thinking to get polycarbonate rear windows.
not really through as i m looking for a possible supplier and prices.
Old 05-06-2007, 09:40 AM
RWD_cossie_wil
RWD_cossie_wil's Avatar
paint the bolts with a spray primer, that will stop them rusting, and put a little bit of sealant/ jointing compound on the back, the non hard setting stuff, that will A) stop the bolts rusting, and B) stop water getting in and causing corrosion, which then stops rusty water running down your window
Old 05-06-2007, 12:11 PM
JanDK
JanDK's Avatar
Did not think of that!!!
Thanks
Old 05-06-2007, 03:17 PM
cossymad
cossymad's Avatar
I took mine out....never opened them!!! All caged out so can't get in back.
mk5 3dr one go straight in though.
Oh and if you want the windows in perspex...I can do them.
Old 05-06-2007, 03:34 PM
JanDK
JanDK's Avatar
Think will do it some day in the near by future .. Perspex may be something for Sim
Old 05-06-2007, 03:50 PM
cossymad
cossymad's Avatar
Does n't make it anyless of an Escort......
Old 05-06-2007, 06:23 PM
JanDK
JanDK's Avatar
I think it gives a very smooth look without them caps, even though they are very small.. nice escort cossymad
Old 06-06-2007, 09:40 PM
Escos Jam
Escos Jam's Avatar
Mine is a standard model and didnt come with pop out rear windows from the factory
Old 07-06-2007, 04:55 AM
JanDK
JanDK's Avatar
Hi Jam,.. that I did not know was "a option" back then..
Cool Escort you have there....
Old 07-06-2007, 08:40 PM
Escos Jam
Escos Jam's Avatar
Thanks mate, appreciate it
Vincereese
01-06-2023 09:14 AM
jessie_rs
11
03-06-2019 04:57 PM
Vincereese
18-08-2015 03:57 PM
Vincereese
16-08-2015 06:38 PM
Bosch
04-08-2015 05:14 PM
Quick Reply: Replacing Escort rear windows
