checking for air leaks
Old 29-05-2007, 04:36 PM
Steve Escos
Steve Escos's Avatar
Default checking for air leaks
Car is now idling high since fitting my pro alloy cooler. Been told to check for air leaks however just wondered what people had used to pressurise the system. Any help appreciated.
Old 30-05-2007, 02:44 PM
Dave Henshall
Dave Henshall's Avatar
its much easier to check for air leaks with the engine running and a can or carb cleaner....
squit the carb cleaner around all the joints/gasgets on the inlet side, when the engine suddenly revs up (becasue its sucked in some of the solvent) you will have found your leak. onyl takes a few mins to do aswell as its fairly obvious when u've found it...
Old 30-05-2007, 03:06 PM
ian sibbert
ian sibbert's Avatar
Or you could use one of these....
Old 30-05-2007, 03:15 PM
Rippers
Monte Geek
Rippers's Avatar
You don't happen to have those big Mikalor hose clamps do you? They where where all leaking on mine
Ian thats a proper tool
Old 30-05-2007, 04:51 PM
Steve Escos
No not using mikalor clamps but when i had a look it looks like the gasket has pushed out in places. Tried spraying carb cleaner but couldn't hear any differences
Old 30-05-2007, 05:21 PM
redrsmk5
redrsmk5's Avatar
can you tell me where the needle is on ur centre pod gauge at idle please???
i posted about air leaks some while back and as yet have not found mine
Old 30-05-2007, 08:09 PM
PewteRS
PewteRS's Avatar
Mine is hunting at idle since fitting my Radtec cooler and i fitted mikalor clamps but they all seem tight..................what was wronbg with them Paul
Old 30-05-2007, 08:14 PM
Rolls
Rolls's Avatar
ditto - are they that bad?
Old 30-05-2007, 08:26 PM
Rippers
Monte Geek
Rippers's Avatar
Both me and Duncos had them removed by Harvey/Ahmed as they there fault is the don't grip completely round. Duncos will hopefully explain more
Old 31-05-2007, 01:34 AM
Arnie
Arnie's Avatar
If the throttle bracket had been removed recently, it could well be those two bolts which go through the plenum......really stupid design. That where my leaks are (I hope)
Old 31-05-2007, 07:40 AM
Dave Henshall
i replaces all my scabby old ford clips with some stainless Hi-Grip ones...
you can then use a 7mm flexi drive 6 point socket to tighten them as tight as you can plus teo full turns = no leaks
wheelwizardrefurbs
21-09-2015 06:42 AM
Flatlinedan
18-09-2015 12:41 PM
talon1
15-09-2015 10:27 AM
BRAMMER
15
14-09-2015 08:52 PM
CrOwSoN15
14-09-2015 11:33 AM
Quick Reply: checking for air leaks
