small turbo engine cuts out when cold
Old 28-05-2007, 05:45 PM
boef
boef's Avatar
Default small turbo engine cuts out when cold
After starting with cold engine the engine cuts out on idle.
This happens only in the first 5 minutes. Sometimes I need to start it a few times. When cutting out it goes very slow from about 1300 rpm to zero.
Had anybody the same experience with a IEC 4 system?
Could it be the idle valve, lambdasensor of temp sensor ?
Any advise is welcome!
Thanks.
Old 29-05-2007, 06:47 AM
Forget lamda and temp sensor, most likely culprit is sticky iscv.
Old 29-05-2007, 07:04 PM
Paul_RS
Paul_RS's Avatar
My ISCV sticks every now and again on my RS 2000, it does the opposite though, idles at around 1500 rpm
Take it apart, give it a clean and a light oil, that should sort it.
3i Jim
20-11-2015 05:12 AM
ar4ibaldo
Ford Focus ST
18-08-2015 04:24 PM
Bailes1992
16-08-2015 07:14 PM
track.focus'd
12-08-2015 05:53 PM
Quick Reply: small turbo engine cuts out when cold
