Top hole on header tank?
Old 23-05-2007, 12:55 AM
morty
morty's Avatar
Default Top hole on header tank?
Redrsmk5 i borrowed this picture of yours to save me the hassle of taking one
I recently bought a polished alloy header tank, however upon going to fit i realised that the Chrome one has 3 holes coming from it when the standard one only has 2.
Where do i run pipe from the top hole to?
I have seen braided hose being used to make it look neat, where could i also get some of that?
Cheers in advance peeps.
Old 23-05-2007, 01:26 AM
L9KOS
L9KOS's Avatar
top pipe is an extra one for connecting to a coolant swirl pot , these basically help keep the coolant bled properly and free from air bubbles that can cause hot spots within the coolant.
if you dont have a swirl pot , simply fit a short length of hose to this fitting on your header tank with a bolt secured in the end with a jubillee clip keeping it in place. This should suffice as a temporary blanking solution untill such a time as you fit a swirl pot to your top hose.
Old 23-05-2007, 04:18 PM
redrsmk5
redrsmk5's Avatar
Default Re: Top hole on header tank?
No problem You really need to get a swirl pot if you dont have one
Old 26-05-2007, 04:55 PM
Escos Jam
Escos Jam's Avatar
You could blank it off mate. I did this when i didnt hav a swirl pot. Looks pish but atleast it'l get you going.
mint_s2
02-09-2015 08:58 AM
AndrewStrang
01-09-2015 11:16 AM
ekjim
17-08-2015 08:57 PM
155lee
14-08-2015 11:21 AM
marky_g
08-08-2015 08:23 AM
Quick Reply: Top hole on header tank?
