Clutch rachet
Old 22-05-2007, 07:05 PM
Gary F
Gary F's Avatar
Default Clutch rachet
How do you fit these?
Mines needed doing for ages but haven't got a clue where to start
Old 23-05-2007, 06:09 AM
Easy enough to do but a bit cramped and fiddly.
You obviously need to take of the clutch pedal to fit it, by removing clips at end of brake clutch pedal shaft, an cable etc off.
I don't think they can be done in situ but have not done one for years, so can't remember.
Old 23-05-2007, 11:42 AM
cossymad
cossymad's Avatar
I put mine in the glove box in the hope it will fit itself
Old 23-05-2007, 11:52 AM
Gary F
Gary F's Avatar
Mines been in the glovey for about 6months
Old 23-05-2007, 11:59 AM
cossymad
cossymad's Avatar
Beat ya.....mines been in there for 14 months
Old 23-05-2007, 01:54 PM
Need to get them fitted then, just budget a week for the morning job!!
Old 23-05-2007, 04:15 PM
S1rst
S1rst's Avatar
I think mine needs doing too. I can hear the clutch pedal click every now and then and just before its a bit harder to get in gear. As soon as it clicks, everthing is fine. Does this sound like i need a new one too?
How much do you think a garage would charge to fit it, and how much is the part itself? Cheers.
Old 23-05-2007, 04:46 PM
cossymad
cossymad's Avatar
Oh yes son, you are ready.
The part £3
The Labour £135 (alledgedly)
Old 23-05-2007, 05:07 PM
S1rst
S1rst's Avatar
The part £3
Ah right, looks like ill be getting me hands dirty then. Cheers.
Old 24-05-2007, 07:04 AM
Gary F
Gary F's Avatar
Yep thats how mine started now I have to let it click every time before changing gear
Infact when I first start the car I have to put it in 3rd so it clicks so I can actually select first
I'll have a crack at it over the weekend........maybe
Old 24-05-2007, 09:11 AM
Easy enough job just a bit cramped working area, I can do it and I'm 54" chest so most should have no problem.
You can get a MANUAL adjuster for these as well, well at you could years ago anyway to replace ratchet.
Old 24-05-2007, 11:53 AM
THE RADMAN
THE RADMAN's Avatar
did mine last yr,would help a lot if you removed the drivers seat as well
Old 10-06-2007, 06:24 PM
Gary F
Gary F's Avatar
Well took the drivers seat out and had a look, and thought fuck that didn't even know where to start.
So took it down to a mates garage job done £20
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
arkeye
Ford Focus ST
20-02-2016 01:22 PM
Quick Reply: Clutch rachet
