indictor problem
indictor problem
well notice today that sometimes when i put either right or left indictor on they both come on at the same time like you put your hazards on.
anyone else had this problem just like to know were to start looking.
does the storks play up or think this is down to the lights earthing out somewhere.
cheers darren
cheers darren
replaced with a new stork and still the same.
dont know if its the problem but i have a clicking noise coming from under the car and when this stops the indicator works again,then the clicking starts again and the indicators come on hazzards again.
sounds like fuel pump area but why would this continuous click?
cheers for all the help now sorted.
traced the clicking noise to under the drivers seat after stripping all that side out i found an laserline alarm box that is still wired in.then i cut back some of the wires in so i could test the volts through.
cut the indicator wire and left the rest in so seems to be fine for now
DavidK
27-09-2015 02:55 PM
Russ Payne
25-09-2015 08:29 PM
