Which Clutch and Suspension ????
Post Miester !
I am lookin to get a Suspension setup fo rthe Escos and i need a decent clutch.
I was thinking Koni Shox and Ahmed Springs and a AP Racing Six Paddle Clutch.
Has anyone had this suspension setup ?? and whic cover plate to i buy ??
Ta..
Ta..
I had an AVO setup on my Escort Cosworth, and then switched to the Koni/Ahmed setup. It’s definitely a softer ride. The AVO’s did handle better when throwing it into roundabouts etc. The AVO’s also performed better when changing direction quickly. But saying that, the Koni/Ahmed spring setup is a great compromise for an everyday driver. Sorry, can’t comment on the clutch side.
John
John
i've got a alcon 6 paddle and a heavy duty cover, the pedal is very light too. But you will need to re-face the fly wheel. i use a new release bearing and cable. all purchased from mike rainbird
oh i use gaz coilovers and i think there great on the road, i had avo before the gaz's and i thought they we're to soft
I'm using Bilsten coilover, and the ride is really harsh, but really good handling. I guess for everyday use, the setup you mentioned would be a really good compromise.
Almost there!
Originally Posted by AlexD
I dont really want coil overs as i have a limited budget
I have heard too you must re-face the fly wheel.
i have koni shocks and PI springs, good set up for the road, but i will prob be changing to eibach springs soon.
as for clutches, i use an AP 6 paddle kit, bit harsh for road use ( vibration / judder ) and i think i am just over the limit of this kit ( 450 bhp / 401 lbf ) as it slips if i do a few launches... ( although AP rate it @ 330 lbf , but did admit it will take a bit more!! )
i spoke to AP directly recently and they told me there cover is only a std ford spec item !! ( been looking into twin plate setups !! )
as for refacing the flywheel, its a get out clause for clutch makers , if the flywheel is not near perfectly flat ( high spots ) you will get some judder and it will cause the clutch to wear rapidly..
the set up you need will depend massively on the car`s spec and YOUR driving style and use...
I'm going to reface my flywheel when I replace my clutch and probably going to lighten and balance it at the same time. It seems odd not to do it when everything is out
I should buy Koni shocks and Eibach springs, best IMO
Ow and the clutch... AP Racing Btw. an Six Paddle Clutch is quite heavy for your feet, especially if your driving in traffic-jam
Get on That!
I am thinking Koni's and Ahmed Springs now ..
Deffo decided on a Six Paddle tho and standard cover
they go hand in hand together if you don't want the feel of a 6 paddle clutch fit a uprated clutch and AP cover plate
on the suspension side i'd say AVO as they are far more adjustable than Koni shocks as the rears only have 3 setting and the Avo have 12-16 setting
John
Re: Which Clutch and Suspension ????
Ta..
Ta..
Im running koni's, ahmed springs and do a bit of track work also, i find they work well. Would alos recommend that you go for the ahm rear beam as well makes a LOAD of difference and transforms the car
Caraholic
If you're going to the trouble of fitting Konis, I would highly recommend the Ahmed springs, they are available in both fast road and track spec. I would NOT fit a budget set of springs (Chassis Dynamics etc), they will compromise the car too much due to being lower than is ideal, so the roll centres will go to rat-shit, and if too low, it will roll MORE.
John,
Regarding the coment on the AVOs out-handling the Konis, I would be interested in knowing what setting you have them on?
As has been said about the flywheel and a paddle clutch, it is IMPERATIVE that this is surface ground to remove any raised hot spots. If you don't then the paddle clutches will drag on the raised hot-spots that you get from slipping the clutch, and this will cause the clutch to judder, be difficult to engage first gear and prematurely wear the clutch out from the drag.
John,
John,
Just been out and checked the car. The fronts are on one full turn to firm, and I believe the backs haven’t been adjusted yet.
John
Caraholic
Try the rears on medium, you may find some greater control with only a small loss of comfort .
Also, when you know you're going to do some spirited driving, turn the fronts up as high as they will go - turn in will be vastly improved. You can always put the back again for poodling around .
That is why you have adjustable suspension .
Report back on your findings .
John
SMILER258
28-09-2015 09:04 AM
