boost controll
Old 13-05-2007, 10:41 AM
K500BHP
K500BHP's Avatar
Default boost controll
Has anyone tried alternative methods of boost controll IE apexi or hks items on their cos and what are the pro's and cons that you found?????????
Old 13-05-2007, 11:50 AM
Gary F
Gary F's Avatar
Pro's go faster
Con's lose your engine
Old 13-05-2007, 01:09 PM
Nash
Cake lover!
Nash's Avatar
I have an Apexi AVC-R that i will be fitting to mine once the new engine goes in.
Cons
Has to be wired in and needs a wheel speed input to use all the features.
Needs to be set up by someone if you dont know what your doing.
Idiot owners who turn the boost past its safe cut off point, complain this is what killed there engine.
Not common in the Cossie world so limmited info out there.
Pros
Has a safety feature that if the unit fails it will only give you actuator pressure, unlike Air injectors that will give you unlimmited boost.
Can run different boost settings for each gear and have 3 programs eg: Wet, Dry, and OFF[actuator pressure].
Scramble button function can be fitted to give a set amount of over boost for a set period.
Can give Throttle possion, Duty, Speed, Peak recall. Theres a few more but thats just off the top of my head.
Old 15-05-2007, 07:47 AM
Gordon1
Gordon1's Avatar
we have fitted a few apexi avcrs and get on very well with them too
Old 17-05-2007, 12:29 PM
DENNIS
DENNIS's Avatar
i have the Apexi - AVCR, been using it for near on 2 years now and is faultless, real good bit kit.
only down side is cost and may need to be fitted and set up by a pro tuner if you are a bit unsure ( the instruction`s are clear )
i still have not as yet got the speed sensor function on it, but its fully programmable in car.
its the way to go
Old 17-05-2007, 12:58 PM
AlexD
Post Miester !
AlexD's Avatar
I fitted a Greddy to the saph, could never get it setup correctly
timsrs
13-11-2018 11:48 AM
Mark RS
12-10-2015 06:01 AM
fordrallycar
30-09-2015 07:57 PM
stevecfrst1
30-09-2015 05:18 AM
Russ Payne
25-09-2015 08:29 PM
Quick Reply: boost controll
