Attention Owners of Escort Cos wasted spark converted cars..
Old 10-05-2007, 09:39 PM
Gavin E-Cos
Gavin E-Cos's Avatar
Default Attention Owners of Escort Cos wasted spark converted cars..
Hi,
Just a few quick and easy questions...
What bracket did you use to mount your coil pack? pics?
Where did you mount it? pics?
What leads did you use and how did you route them to the coil pack? pics?
What spark plug gap do you now run?
Many thanks,
Gavin
Old 11-05-2007, 08:03 AM
Rolls
Rolls's Avatar
easy -
Bracket from fusion, although I'm going to get him to make another - probably in a similar style to Paul's as the holes don't quite line up wit the original coil bolts.
Mounted in the original coil position.
Leads bought from MSD as part of the kit.. -
Plug gap - currently at 0.7.
Rich
Old 11-05-2007, 08:14 AM
The DIVA
The DIVA's Avatar
Custom made brackets(by me) on a zetec baseplate......
Looks good(IMO of course ) and makes for an easy route for the leads.....
Old 11-05-2007, 09:01 AM
Dave Henshall
Dave Henshall's Avatar
i made a custom ally bracket that used the original bolts - so no drilling of the wings was necessary
Old 11-05-2007, 11:50 AM
Rolls
Rolls's Avatar
Dave - did you leave that supressor in the wiring when you did the coilpack conversion? - I removed it from mine as per the instructuions....???
Old 12-05-2007, 01:08 PM
Arnie
Arnie's Avatar
it's a bit messy at the moment, need to tidy it up
Old 12-05-2007, 01:51 PM
DENNIS
DENNIS's Avatar
i mounted my one a bit different, ( water deflector removed )
and just for good measure, the distributor cap cover
the diva,
that's , where i wanted to mount my one but the breather is in the way
Old 12-05-2007, 03:15 PM
Arnie
Arnie's Avatar
nice and neat , but only work for non-aircon models
Old 17-05-2007, 07:11 AM
Gavin E-Cos
Thanks for your pictures & info.
I will have to sort out a bracket of some kind and will look at the Fusion one.
I will have to get some motorsport leads as my current ones will be too short.
Diva yours is very neat, and looks good, although I will aim to get the coil pack in the standard place if I can.
PS anyone got a good second hand front deflector for sale?
Thanks,
Gavin
Old 17-05-2007, 11:16 AM
Arnie
Arnie's Avatar
if it's second hand, it won't be good
Old 17-05-2007, 12:42 PM
Gavin E-Cos
I wouldnt take much to improve my current one!
Old 17-05-2007, 12:48 PM
Gavin E-Cos
I assume the suppressor is for stop interference on your radio? I again assume that using a coilpack has no interference?
Old 17-05-2007, 01:00 PM
Dave Henshall
correct as there is no arcing on the system other than at the plugs which are already quite well earthed
Old 31-05-2007, 06:41 PM
Damo V
Damo V's Avatar
Mine
Old 01-06-2007, 11:18 AM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Gav, it's not that your leads will be too short, it's that they won't fit on the oil-pack, as it has different connectors (I do the leads ).
Here's mine:
The iginition amplifiers (when I needed such things ):
Old 01-06-2007, 01:05 PM
Gavin E-Cos
Thanks Damo, very neat.
Mike, glad you mentioned that as I thought they were std motorsport leads used?
Gav
Old 01-06-2007, 01:48 PM
Mike Rainbird
Caraholic
Gav
Nope, the coilpack connectors are TOTALLY different - you can see in the photos that I put up - now go look at your ones .
Topjoe9
20-08-2015 02:38 PM
Escortdriver1
19-08-2015 09:02 PM
IAN RS2k
18-08-2015 07:51 PM
cozzy jeff
14-08-2015 05:46 PM
Escortdriver1
31-07-2015 02:36 PM
Quick Reply: Attention Owners of Escort Cos wasted spark converted cars..
