md software and some problems till i have it
so
as Stu doesn't know anything more, and me also not
here s the problem
I can rev all gears up to 7000 rpm, just not the 5th, at 250 km/h the power is gone from one to the other second.
i m running greens, t34 with 1,8 bar overboost and 1,5 bar holding pressure, 3 inch exhaust, rs500 intercooler and a software from Stu, which normally shall work. Fuel pump is a 023 Bosch Motorsport.
Here is a video, where you can see the problem perhaps a bit....
no more revving than 6500 rpm in 5th is possible, so i m thinking, there is no sensor failing, as this must be in every gear then...
http://www.turbostylez.de/download/v...cossie_sim.zip
its xvid codec
it feels a bit like a speed limiter or hard fuel cut, I don't really know what it is....
here s the problem
its xvid codec
no all gears are okay, just the 5th gear makes the problem.
i can rev 4th till 7200 rpm - did not try more, but i might think that more is possible, but i ve a stock head, so won t try, I don't catch the problem, as I think the software from Stu is good!!
Russ Payne
25-09-2015 08:29 PM
