abs light? please help...
Old 03-05-2007, 10:36 PM
L3 COS
L3 COS's Avatar
Default abs light? please help...
hi guys ive got the orange abs light staying on,on the dash,the red one goes out fine,any ideas wot could be the problem?
im guessing a sensor perhaps? is there any way of checking or testing?
as always thanks for any help..
Old 04-05-2007, 06:47 AM
I would in the first instance just have a wiggle if the connectors around the pump to see if it is one of these.
Old 04-05-2007, 09:57 AM
- Sim -
- Sim -'s Avatar
yes and also check all fuses at the abs ecu, and the sensor under the passenger seat, if there's a problem.
that caused my abs to fail for some months....
Old 04-05-2007, 10:12 AM
cossymad
cossymad's Avatar
The sensor always get covered in crap. Undo them and give them a clean up as well
Old 04-05-2007, 05:46 PM
L3 COS
L3 COS's Avatar
thanks for yr replies guys
cossymad which sensor are you talking about and wheres it located?
Old 04-05-2007, 05:55 PM
ECOS95
ECOS95's Avatar
I'd imagine he means the Wheel sensors.
Old 04-05-2007, 07:59 PM
L3 COS
L3 COS's Avatar
thankyou
il check and clean them up see wot happens..
Old 05-05-2007, 07:49 AM
cossymad
cossymad's Avatar
Yes right behind the wheel, behind the disc you will see a sensor with a wire going to it, which is held in with a star bolt. They are close to the disc and get covered in crap.
Usually if the sensor fails, the ABS light goes out, but the ABS keeps kicking in!!
Old 05-05-2007, 08:35 AM
MarkN
MarkN's Avatar
The orange light also illuminates if the computer thinks there is not enough pressure in the accumulator on top of the master cylinder. You can make it come on by pumping the brake pedal for a few seconds and then the light comes on to indicate low pressure.
Point is it might be the pressure switch - I have seen this a couple of times previously...
Old 06-05-2007, 09:52 AM
Rolls
Rolls's Avatar
Any ideas how to actually get the sensors out at all chap?
And how much are they if they do need replacing?
Old 06-05-2007, 10:22 AM
THE RADMAN
THE RADMAN's Avatar
remove the bolt,use loads of wd40 if they have never been removed before, and try and gently tap the rear end of the sensor from side to side to get it moving,then you can keep twisting it untill you can pull it out,dont try to lever it as it will snap off and they cost a fortune new
Old 06-05-2007, 11:56 AM
Rolls
Rolls's Avatar
Cheers - will give that a go!
Old 06-05-2007, 02:50 PM
ECOS95
ECOS95's Avatar
They were around the £100 mark but that was a few years ago when I bought mine.
muzzman1
30-09-2015 08:59 PM
morg65
Escort MK 5 / MK 6
23-09-2015 03:19 PM
Quick Reply: abs light? please help...
