Re-Fitting Cam Cover any tips?
i have just had it refurbished and have got a Cometic gasket and half moons any tips on re-fitting?
kool
that simple ehh.
ive just heard of some people having probs with em leaking etc.
wheni took the rocker off before powder coating it i seen someone had used some kinda sealer before.
Can i get this at my local motorstores? and is it simply called gasket sealer?
that simple ehh.
The stuff you refer to is SIKAFLEX, not SILKAFLEX.
Not suitable at all, if you phone up LOCTITE on 01442 278100, they will be able to point you to your nearest supplier.
5910 is like a slightly softer plasticine in consistency.
When I first started using it years ago I gave all of my HYLOMAR away, about 10 -12 tubes, and have never looked back.
I have to date NEVER had a leak from a component put together with the 5910.
There is another loctite product 5900 which is a MUCH FASTER SETTING ONE, ie about 2 minutes!!.
The stuff is 50% dearer than others but it works.
