Escort cosworth T25 Boost Hose kit with DumpValve fitting
Old 27-04-2007, 04:44 PM
vaiche_boa
vaiche_boa's Avatar
Default Escort cosworth T25 Boost Hose kit with DumpValve fitting
Hi
Someone know if some hose´s mark have the hose to turbo to the Escort cosworth T25 WITH dump valve fitting. I never saw it. Someone know??
A lot of thanks.
Old 27-04-2007, 04:52 PM
cossymad
cossymad's Avatar
Samco hose does, or we do a bolt on dump valve that goes direct to atmosphere from turbo
Old 28-04-2007, 09:08 PM
cossie rich
cossie rich's Avatar
i didn't think the small turbo liked running with a dump valve???????
Old 29-04-2007, 08:27 AM
redrsmk5
redrsmk5's Avatar
Mine does
Old 29-04-2007, 04:12 PM
RWD_cossie_wil
RWD_cossie_wil's Avatar
Small Turbo cars NEED a RECIRCUATING dump valve, as the airflow meter has already told the ECU how much fuel to put in for the mass of air passing through it. No dump valve at all and the air goes back through the Air flow meter, and causes over-fuelling, due to the same air being calculated for fuel wise twice. An Atmospheric dump valve means air that is meant to go through the engine goes straight out to atmosphere, and the fuel that has been added by the airflow meter just pools into the intake and again can cause rough running and overfueling.
My car is the test bed for the MSD EEC IV 350 BHP conversion, and one of the vital modifications is making sure there is provision for a recirculating dump valve, and personllly I would NEVER run no or to atmosphere dump valve as the car will never be 100% without a recirc
Old 30-04-2007, 01:50 PM
vaiche_boa
vaiche_boa's Avatar
thank to all
Old 30-04-2007, 03:54 PM
cossymad
cossymad's Avatar
I have always run one
Escortdriver1
31-07-2015 02:36 PM
Old ford
31-07-2015 06:50 AM
Quick Reply: Escort cosworth T25 Boost Hose kit with DumpValve fitting
