Small Turbo ECossy Spark Plug Leads and Coils
Hi, where can I get some of these leads from? What is the correct description for the Spark Plug Coils, I can't find them anywhere in the service manual. Also, any ideas on cost for both?
Simon
Do you remember me telling you about the coilpack replacement on mine???
Well i went to my local ford garage and asked how much for 2 escorth cosworth ignition coil packs.....Ł125 each mate!!! F#@k that off i thought!!! So Anyway a quick call to PJ Motorsport sorted me out for half that price. Paul informed me that the Escort RS2000 ones are exactly the same all you do is swap the connection node from the RS2000 coilpack for the old one off the Coilpack on the cossie and Heypresto!! I paid Ł124 for both coilpacks and true to his word they fit and work as escort cosworth ones should do, not one misfire or one ounce of trouble from them and theyve been on for 5k.
The leads are always on ebay in cosworth shop or Graham Goode.
i have my old leads and packs sitting here off mine pm me if you wanna buy them off me .. not needed now i use autronic
ADAMSKI FRST:- PM sent mucker
I have taken them off and I can't believe what I found , I can only presume from investigation that some numpty has tried to fit one of them the wrong way around to the aluminium spacer and look at the damage to the underside of the coil pack , I presume this is why i'm getting a misfire around 3500/4000 + rpm (It's OK on tick-over though)??
Anutternutter
21-08-2015 06:07 PM
Zoggon
10-08-2015 10:39 AM
