All the clever peeps!
Right ladies & Gents, need your help finding & understanding some parts......
First off, whats this for? And can you get new ones?
Also what are these relays for? found at the back of the bulkhead?
And can anybody give me the correct Finis codes for these?? (found in engine bay by chassis leg).
Jason
Jason
the relays behind the ar to summat to do with the fans IIRC
and the clips ur after in the bottom pic ur best of taking the clip into ford and matching it up on the screen as theres loads of different types.
HTH
HTH
i tried to get the big loom brackets/clips before and they dont exist, well not at my dealers anyway i should try though as i would have thought they would be easy enough to get hold of,top pic is fuel system purge solenoid, it vents the fumes from the tank in to the inlet manifold [after they have passed through the carbon cannister,which is mounted under the o/s wheel arch]
They are also used on some ford car that have HEATED FRONT SCREENS to admit extra air so sudden load does not cause stalling, I use two of them for my dump valveS, quiet/noisy,chatter, so this way you can have all three!!!
Franco: the clips that hold the loom in picture 4 clean up really well if you soak them in hot water after spraying them with cillit bang,if you have any dirt or grime left on them it will come off with an ajax pad, i did mine!!!..........sad isnt it
and the bottom loom clips are still available as ive bought some on a few weeks ago when i did my engine work.
Originally Posted by PewteRS
Originally Posted by redrsmk5
Franco: the clips that hold the loom in picture 4 clean up really well if you soak them in hot water after spraying them with cillit bang,if you have any dirt or grime left on them it will come off with an ajax pad, i did mine!!!..........sad isn't it
THE RADMAN
Hang on so that vents fuel vapours into the inlet AND helps demist heated front screens!! And how does the DV work with that canister then?
RS Bowk
Escort_RS_Turbo
Yeah noted all the numbers down on them so that might be easier, i don't really get the time to get down there (Its far too easy for the ford div's to say 'NAAAH MATE, ITS DISCONTINUED!! ).
Monte Geek
Application :
Escort Cosworth , RS Turbo, XR3i, RS1600
Sierra Cosworth
Description :
FIVE X Brand New Genuine Ford Wiring Clips
Finis Code :
6-105-03-4X5
No longer available from your local ford dealer!!
BUY TODAY AND SAVE ££££`S
That bloke always puts no longer available from ford for any ford item
Franco PM Doo on here he will def help u out hes NOT ur usuall Ford parts guy and he will actually look for you.
HTH
HTH
Application :
Sierra Cosworth
Description :
Finis Code :
6-105-03-4X5
HTH
HTH
Ps the boots will be hand delivered to you at Central day if thats okay with you? Pm the numpty above Paul R.............. Or just look for the homo Norfolk stand.......He'll be there!
Testing the future
THE RADMAN
it's just a little solenoid valve that is normally closed so nothing flows through the pipe until you apply 12V and open it
what tabetha has done is put some more in the signal hose to the dump valve to be able to control if it opens or not
paceo
25-09-2015 08:05 PM
paceo
17-09-2015 12:12 PM
