How much does MT75 clutch arm move?
As topic says, how much does MT75 clutch arm move, when clutch pedal is full pressed and when in normal position (clutch not pressed). I can measure that later, but would be great if someone could, or has measured it. I also need to know how far the arm is from the gearbox case hole when pedal pressed and when not.
