anti roll bar captive nut
one of the captive nuts on the anti roll bar has dissapeared into the chassis leg.Has anyone suffered this before and how did you fix it.
Originally Posted by tabetha
I used a nut, welded to a piece of thin rod(3mm) then inserted it through the hole that is there(at the side) and wiggled it around until it lined up.
steve
ive seen this repaired with half of a u bolt and nut stuck through from the side of the leg there is a hole already as above. you can hold it in position while fitting the bracket back up very easy
07-10-2015 12:56 PM
DavidK
27-09-2015 02:55 PM
