Washer bottle query?
Right sorting out the broken bracket on the bottle last night, and noticed this second pump on the side............
Whats it for?
Also dont suppose anybody's got one of these spare.... Mines broken!
Jason
Whats it for?
Jason
With the 1/2" inlet to pump or there abouts anyway defo the h/light washers pump.
Amaze yourself go along to HALFORDS!!! stock item, amazing but true, from memory about Ł6, hanging up with all things washy pipey!!
If still stuck give me a pm and I'll get you one.
If its for the headlight washers, i'll blank it off as i'll be adding caps. But the piece broken off i assume is the split for the front & rear washer supply.........
You reckon these can be bought from Halfrauds yeah?? I'll take a peek! Will let you know how i get on if not.
Monte Geek
Jay just something to check, thats deffinalty the headlight washer pump.. can you remember when you checked to see if it the headlight washers worked did you have the headlights on? as I was just reading the Escort Cosworth user manual and it says they only work when the headlights are turned on
THEY do indeed only work with the headlights ion on sapphys so ecy wil no doubt be the same, this is donme to conserve water as they use a hel of a lot.
The washer pumps exactly the same are in my local HALFORDS in EAST DEREHAM, and will look in THETFORD today and get you a part number!!
They are also found on a lot of other fords like mondys, anc can (just) be removed from these with out bottle removal!!
1 Post
and..... if you lift up the back seat base in the car you will find 2 off of said headlamp washer pumps there as spares.... - alright they were fir the homologation water injection, but they are in fact the same 1985 granada screen washer pumps
I'll take the pump down with me next weekend! Thanks!
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
155lee
24-10-2015 11:11 AM
DavidK
27-09-2015 02:55 PM
