rear arm bushes
rear arm bushes
been told to get the original rear arm bushes from ford as there alot better than the poly ones but how much!!!!!! £64 x 4!
anywhere cheaper?!!!
I have poly everywhere as I did on my last sierra(xr4i) and the one before that(2.0gl), currently a cossie all polied up I get NO VIBRATION AT ANY SPEED ANYWHERE, not a sausage, and neither did I on any other of mine.
My dad xr4i(4litre V8) also poly everywhere and no vibration anywhere.
I regularly do 135+ and still none.
Still can't figure why a POLY bush COULD transmit more vibration than a metal one ?, maybe that's why all engine mounts are metal as they transmit less vibration ?
mines poly bushed and no vibes at all !!!!!!,cos ford develop items dont mean there are gospel!!!!!!!!!!!!!!,
ford engine tolerances are crap to make a point!!!!!!!!
Almost there!
but you will be daft to move away from the standard joints/bush setup on the trailing arms to go for poly.
if you are insistant on changing away from origonal then go for nylon and not poly, they will do a much better job of holding the trailings as they should be than poly will ever do.
Tony W
09-09-2015 12:08 PM
