Removing and fitting front bumper...- Which bolts...
Old 18-02-2007, 03:30 PM
Rolls
Rolls's Avatar
Default Removing and fitting front bumper...- Which bolts...
HI guys, I've got a question on how exactly you are suppsoed to remove the front bumper...
Acording to this thread : https://passionford.com/forum/viewtopic.php?t=228767 there seems to be 2 ways of doing it? - I've removed it as per the ford workshop manual (or at least i think I have???) by undoing the 2 bolts that are under the front of the bumper, and accessible front the front of of the car without jacking it up... - Although on the thread above, these are height adjustment bolts??? - Indeed, they will adjust the height of the bumper as you do them up, but are there other bolts that I should have removed? - Here is a pic of the front of the car as it is:
(and I have a horible feeling that this rapidly going to go from a quick tidy up to a front end overhaul - can't think of anyone who has done the same eh! - oh well, roll on fitting my new bells, and quip! )
Has anyone got any comments/ can advise on the correct way? - On all of the pic's I've seen there are not the 2 little bars sticking out at there are on mine where the "adjustment" is??
Also, is there a certain trick to re-fitting the bloody thing? - Unless i'm being completely usless its a complete ball ache of a job to try and do on your own....??
Cheers,
Rich
Old 18-02-2007, 03:59 PM
Dunccoss
Dunccoss's Avatar
the best way is to remove the bolts that are under the car on the box frame, you undo one off the bolts from each side and remove then the other 2 you just need to undo as they will slide out, as i said in the other thread mate
Old 18-02-2007, 04:02 PM
PewteRS
PewteRS's Avatar
When i had mine off i never touched the adjusters. There are 4 bolts that hold the adjuster bars on, just loosen the frontal ones and remove the rear ones and then its just the twist butterfly things under the lights and it will slide off. (disconnect the lights obviously)
Old 18-02-2007, 04:15 PM
Rolls
Rolls's Avatar
Ritye then - so it looks like i've undone the hight adjusters then! - Looks like the Cossie workshop manual is about as clear as mud - esp. as they tell you to remove the bolts that sit behind the number plate too! - Marvelous!
Cheers for the info guys!
Old 18-02-2007, 04:55 PM
Stoo
Stoo's Avatar
NOOOOOOOOOOOO! Not the height adjusters! I messed mine up taking it off that way and my bumper sat shit ever since. I had to get Andy to weld new brackets on, so be carefull when putting them back on, they're a pig to do...
Old 18-02-2007, 05:44 PM
THE RADMAN
THE RADMAN's Avatar
hopefully youve not stripped the threads on the adjusters
Old 18-02-2007, 05:51 PM
Rolls
Rolls's Avatar
lol- , nah, the thread is fine! - T'is ashame that the ford workshop manual isn't particularly clear - oh well... looks like i'll have fun at the weekend
Old 18-02-2007, 07:09 PM
adamski frst
adamski frst's Avatar
Location: brum/shropshire drives:- frst / escort cossie
mine were i had to 'adjust them' the prev owner rounded the 1
Old 20-02-2007, 09:05 PM
Paul Eggleton
Paul Eggleton's Avatar
HOw's the old girl going Rich??
Old 20-02-2007, 09:12 PM
kjc300
kjc300's Avatar
As most did the same the first time they took theirs off!! Me included!!
Old 20-02-2007, 09:31 PM
Rolls
Rolls's Avatar
Yeah, good cheers matey - I will start a thread soon enough in the project room - There will be a fair few updates over the next month or so ...
but here are a few pic's of whats to come....
Old 20-02-2007, 09:57 PM
Stoo
Stoo's Avatar
Old 20-02-2007, 11:10 PM
adamski frst
don't forget the new brake nuts too
Old 21-02-2007, 07:44 AM
Rolls
Rolls's Avatar
on order along with new bells / bobbins matey
Old 24-02-2007, 03:01 PM
Rolls
Rolls's Avatar
Righty then guys - i've stripped the bar pretty mcuh as far as I need to before I start fitting all of my new bits, and i've re0fitted the bumper properly - thankfull the hight adjustment botls were ok! - Just out ofr interest, can you get new "bumper bars" or whatever you want to call them?- i'd like to get some for the wrc bumper rather than going through the hastlel of changing them over...
Old 24-02-2007, 03:08 PM
THE RADMAN
THE RADMAN's Avatar
nope,only came as part of bumper im afraid,unless you can find someone with a knackered bumper to rob them off
Old 24-02-2007, 03:13 PM
Rolls
Rolls's Avatar
oh well... thats that idea of the the window then! - cheers for the info
JoeyBoyden
04-01-2024 02:36 PM
original
30-01-2022 08:20 PM
manuel boeckx
13
03-10-2015 02:29 PM
track.focus'd
12-08-2015 05:53 PM
Quick Reply: Removing and fitting front bumper...- Which bolts...
