Want to give going back to standard ago
As above on my small turbo escos.
I am going to remove the chip, it has a standard actuator, would i need to change/check anything like the injectors???
ben
ben
Originally Posted by the youth
you may need to reconnect the amal valve depending on the chip, as with some chips they are disconnected, the injectors will be unchanged
Steve
Steve
Amal valve is definately connected
Do you guys recommend a session on the rolling road afterwards, just to make sure everything is running right?
Formerly COSSIE_LEE
When I took my (previous owners) "Superchip" off I had to get it rolling road set-up as it was over boosting. Power Engineering adjusted the actuator but it was still over boosting so they got one out of the bin they had just taken off a standard cossie! Safe to say it worked thought.
Originally Posted by RWD_cossie_wil
why do you want to make your car slower?
can always change it back if I don't like it
it's crap, take it from me and save your time and effort - you will have to mess about adjusting the actuator as well, to set the boost which is a pain when you re-chip it because clio 182's are laughing at you
I need to give it a go for a bit as I need to get it remapped.
got a couple of places locally but need to check them out first.
I'll let you know what I think to standard later this week
Went out in it last night as standard, I didn't think it was too bad, but then again my daily drive is a 1.6 mondeo, so anything is quicker than that.
Will be seeing how it goes for a little, but I must admit after reading the the tuning a small turbo cossie thread its making me think I should put the chip back in
Steve
Steve
track.focus'd
12-08-2015 05:53 PM
