broken down due to one blown fuse
my brothers big turbo escos has been off the road for about 3 weeks now as it broke down - no spark had the tester on it all sensor were getting power still no spark but power going into the dizzy from the coil , changed the phase sensor still no spark , checked fuse box fuses and a 10amp had blown (fuse 3) changed that and it fired up sweet as a nut first time , not sure what the fuse is for ? says KAT on the fusebox cover , does anyone know what fuse it is as we pulled it out and it cus the engine out dead replaced it and fine bit of a mystery
Are you sure it's not KAM, KEEP ALIVE MEMORY.
It basically stores fine tuning info for engine running, did not realise it would prevent running though if blown.
Originally Posted by Damo V
Lambda or loom to lambda is fudged.... or could be fuse box...
07-10-2015 12:56 PM
