Which Fuel Pump ??
Old 31-01-2007, 08:12 AM
AlexD
Post Miester !
AlexD's Avatar
Default Which Fuel Pump ??
I have been lookin around, and there are a few to choose from.
Walbro.
FSE
Bosch
etc..
Which one do most people use ?? I am after a direct replacement.
Ta....
Al......
Old 31-01-2007, 08:21 AM
K500BHP
K500BHP's Avatar
FSE direct replacement 255 L/h and only £95 + vat
Old 31-01-2007, 08:32 AM
AlexD
Post Miester !
AlexD's Avatar
I was thinking a Bosch 023 Pump..
But the FSE uprated one flows 255 ltrs/per hour as does the Walbro.
The Bosch is only 210 ltrs/per hour. But i think it has a higher flow pressure.
Help....
Old 31-01-2007, 08:41 AM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
What power out-put?
Old 31-01-2007, 09:10 AM
AlexD
Post Miester !
AlexD's Avatar
Mine is a T34, Stage 3 Greens, MSD Closed Loop, ported head, Was dyno'd at 360 BHP.
Old 31-01-2007, 09:21 AM
Mike Rainbird
Caraholic
Bosch 023 will be fine for that. I have had no personal experience of the others, but have heard that they don't perform as well as the figures suggest...
Old 31-01-2007, 09:30 AM
AlexD
Post Miester !
AlexD's Avatar
I will go for that then, I presume all i need is the pump and your fitting kit ???
Old 31-01-2007, 10:00 AM
Mike Rainbird
Caraholic
Yep .
Old 31-01-2007, 11:25 AM
Arnie
Arnie's Avatar
I'm using FSE, it's a direct replacement and no fitting kit required. but we've done a test locally for a couple of brand of fuel pumps, apparently Walbro had the best flow rate
Old 31-01-2007, 09:15 PM
Damo V
Damo V's Avatar
Bosch 023
Old 01-02-2007, 07:45 AM
mcossie
mcossie's Avatar
FSE uprated is the cheappest choice....
Old 01-02-2007, 11:06 AM
ECOS95
ECOS95's Avatar
I wouldn't want to skrimp on an important part as a Fuel pump just to save a few pennies
Old 01-02-2007, 05:54 PM
L9KOS
L9KOS's Avatar
you have to watch the likes of the fse and sytec units , as although these have decent pressure and flow rates they tend to use the original push fittings from the original pump , these fittings cannot deal with the increased pressure and tend to burst the seals under load.... not good if ya on boost at the time eh!!!! could prove quite costly.
i'd stick to the bosch item as these use proper aeroquip fittings and are a much more reliable option!! yes they may be a bit more of a fuk on to fit... but it's definately worth it!!
ya'll need this little lot......
the difference in size to the original is err... fairly noticable!!! lol.......
JK12
33
26-04-2021 12:09 PM
155lee
27-10-2015 04:55 AM
155lee
24-10-2015 11:11 AM
wheelwizardrefurbs
23-09-2015 09:21 PM
tib2220
14-09-2015 12:33 PM
Quick Reply: Which Fuel Pump ??
