POLLY BUSHES
Old 28-01-2007, 09:16 PM
cos im worth it
On here to much!!
cos im worth it's Avatar
Default POLLY BUSHES
Hi all, looking to buy a full front set of polly bushes for the Escort, what polly bushes do you recommend? Thanks Mark
Old 29-01-2007, 07:01 PM
redrsmk5
redrsmk5's Avatar
Hi Mark
I have powerflex on mine all round and cant fault them one bit!
Old 29-01-2007, 07:23 PM
cos im worth it
On here to much!!
Cheers Martin, i will probably go with powerflex ones anyway, i was just wondering about the others ie Deflex and the ones thats advertised in FF, the superflex ones? Are all powerflex bushes one colour or is there dif colours ones? Thanks Mark
Old 29-01-2007, 07:53 PM
DENNIS
DENNIS's Avatar
i use deflex, i have heard mixed stories about them, but i have had no probs at all....
Old 29-01-2007, 08:49 PM
cos im worth it
On here to much!!
Cheers Dennis, i have heard mixed reports too mate.
Old 29-01-2007, 09:29 PM
THE RADMAN
THE RADMAN's Avatar
ive got ggr ones on the front and rally design on the rear,deflex rear spring insulators,all work perfectly
Old 29-01-2007, 09:57 PM
S1rst
S1rst's Avatar
Ive got Powerflex in yellow, although my anti-roll bar bushes are red and im sure there powerflex too. I assume they'll be available in yellow red and blue.
Old 30-01-2007, 08:06 AM
Mr.Ford
Mr.Ford's Avatar
what are normal prices for a complete set Poly bushes???
And where can you order them cheap?
Old 30-01-2007, 09:17 AM
dojj
Resident Wrestling Legend
dojj's Avatar
powerflex all the way mate, they do cost but you spend half the time fiting them
done them on my sierra and it took 20 minutes a side from getting the tools out to putting them back again (inners AND outers)
the ones that rally design do took me 12 hours
and the superflex ones tend to go a bit wobbly after a while
the powerflex ones are still going strong after 9 years
one word of warning though, if you are thinking of doing the inners make sure that the sleve goes into the space in the crossmember first otherwise no amount of pushing and straining will get it up there, better to smooth off a bit of the metal sleeve than to try and get the crossmemebr to widen a bit
Old 30-01-2007, 09:19 AM
AlexD
Post Miester !
AlexD's Avatar
www.rallydesign.co.uk
I used powerflex on the front top mounts and rear beam big bushes.
and the rest Poly Sport or Poly Bush, cheap and do the job well.
I use them on the sapph too.
Old 30-01-2007, 02:43 PM
cos im worth it
On here to much!!
Thanks guys, Think ill go Powerflex as heard nothing but good reports about them.
Dojj my god 12 hours mate! would have had enough after an hour and probably put them in the bin! HA HA. Powerflex lasting you 9 years, cant argue with that.
Old 30-01-2007, 07:11 PM
dojj
dojj's Avatar
they guy came a long way to get them fitted, but they were way to oily and stretchy, and with the powerflex ones they go to a point and then they will pop in, these ones kept on stretching and there was absolutly no way we oculd get them to pop in
in the end we decided that it was just a case of using brute force to bend everything into position and slot them home, with the powerflex ones i tend to put them onto the arb first, then put the tca on, then the inners go into the crossmember, then slide the inner sleve into the tca, then slot the front one over the top
never failed me yet and you get a bit more play getting them on
i'll do a quick fitting thing the next time i've got a few spare minutes at the other garage with the camera
Old 30-01-2007, 07:34 PM
cos im worth it
On here to much!!
Thanks Dojj your a star mate.
Old 30-01-2007, 08:28 PM
cos im worth it
On here to much!!
PART RANGE DESCRIPTION
Powerflex polyurethane suspension bushes are much stiffer than standard and contribute to more precise handling. They are supplied in 3 colours depending on the rating of the bush.
Yellow - the softest compound for exhaust mounts and other bushes where flexibility is required (depending on the car).
Purple - a medium compound for use where some flexibility is required (depending on the car).
Black - the stiffest compound for use where maximum rigidity is required (depending on the car).
just found this on a performance centre site just incase it helps anyone else interested in fitting them!
Old 30-01-2007, 08:36 PM
dojj
dojj's Avatar
i'll even take a pic of the 9 year old ones for you too
Old 30-01-2007, 08:49 PM
cos im worth it
On here to much!!
Top man
gcfcos
59
06-10-2015 05:04 PM
DavidK
27-09-2015 02:55 PM
Quick Reply: POLLY BUSHES
