Removing Fuel Tank & Fitting a New pump ???
Old 25-01-2007, 08:33 AM
AlexD
Post Miester !
AlexD's Avatar
Default Removing Fuel Tank & Fitting a New pump ???
Need some guidance on how to
Does anyone have any pics ???
Cheers..
Al...
Old 26-01-2007, 12:37 AM
Arnie
Arnie's Avatar
This is the instruction I've got from GGR, unfortunately I didn't take any pics when I removed mine, hope it helps
FUEL PUMP
The Escort Cosworth fuel pump is fitted inside the top of the fuel tank, as an integral assembly with the fuel gauge sender unit. To gain access to this unit the fuel tank must first be removed from the vehicle.
For ease of removal, it is strongly advised that the fuel level in the tank is as low as possible due to the excessive weight.
When the fuel tank is removed from the vehicle, the combined fuel pump and gauge sender unit is clearly seen in the top of the tank. The pump unit is retained into the tank by a castellated steel ring that locates in teeth set in the outside of the tank unit, pressing the pump assembly down into the fuel tank.
Before removing the original pump assembly, it is advisable to clean the top of the fuel tank, to prevent any foreign particles from entering the tank when the assembly is removed.
To remove the pump unit from the tank, carefully knock the retaining ring in an anti-clockwise direction, to disconnect it from its retaining teeth. When the ring has been removed, the pump assembly can be carefully lifted out of the fuel tank, taking care not to damage the float assembly on the fuel gauge sender unit.
Fitting the new pump assembly is almost the reverse operation.
Before fitting the new unit, please ensure that the rubber sealing gasket is correctly in place in the top of the tank.
Due to the increased size of the new pump, and the neoprene covering, the new assembly does not drop into the tank as easily as the original unit. Careful use of light force is required to ease the new pump into position. Drop the fuel gauge float assembly side into the tank first, then carefully ease the opening in the tank slightly with a small lever, to allow the pump to lower into the tank. You will notice that there is an arrow marked on the top of the tank, and on top of the pump unit, when these two marks are aligned, you will see that the retaining plate for the unit locates with the top of the fuel tank.
The fuel tank may now be re-fitted to the vehicle, the original fuel return line is fitted to the top of the pump unit as before. A new fuel pressure hose is supplied in the kit to replace the original item from the fuel pump, to the fuel filter. Ensure that this new high pressure hose is safely routed and secured.
Old 26-01-2007, 09:23 AM
Mr.Ford
Mr.Ford's Avatar
@ Arnie
That's a very good instruction
Old 26-01-2007, 12:50 PM
AlexD
Post Miester !
AlexD's Avatar
Thats great for the Pump Mate..
Any tips on the removal of the tank itself ??
Ta...
Old 28-01-2007, 12:54 AM
Arnie
Arnie's Avatar
Use up/pump out as much fuel as possible, the damn thing is really heavy with fuel inside! I think it's just two metal straps holding the tank in place, once u put the car on stand you can see it clearly and it's really simple
Old 01-02-2007, 02:28 PM
Dave Henshall
Dave Henshall's Avatar
red pipe on the pump is return - remember that...
and you'll need to order a new rubber gasket and locking ring more than likely as these perish with age....
also dont forget to replace the fuel filter while you are under there
Old 01-02-2007, 02:34 PM
AlexD
Post Miester !
AlexD's Avatar
Cheers Dave...
Old 01-02-2007, 06:48 PM
L9KOS
L9KOS's Avatar
removing the tank is a piece of piss as it is only held in place by 2 straps...
just be sure to give the 2 x 13mm headed bolts a fair dosage of wd40 prior to removal as they are prone to snapping.
make sure the tank is drained , once ya have ya car into the raised working position and secured on axle stands , support the fuel tank on a trolley jack and then remove the 2 securing straps.
once the straps are out of the way , drop the jack a couple of inches to obtain access to all the pipework etc.. on the tank top , there should be 2 pipes on the tank top (a feed and return) which should come off no bother as they are simply a case of pushing in the 2 tabs on the pipe and sliding it off.
also to remove on the tank top is the wiring for the pump , again not a problem as it's just 1 multiplug.
inside the rear wheel arch you will find the filler neck pipes , one large filler pipe and one vent pipe , these are merely held in place with jubilee clips.
once everything is un-done , lower the tank to the ground.
once the tank is out from under the car it is advisable to steam clean the tank top to remove any dust grit or debris.
removal of the tank top is simple , it is held in place by a single locking ring which is easilly removed by knocking it around with a blunt chisel and a hammer (carefully).
RIGHT , ON TO THE PUMP.....
you have to watch the likes of the fse and sytec units , as although these have decent pressure and flow rates they tend to use the original push fittings from the original pump , these fittings cannot deal with the increased pressure and tend to burst the seals under load.... not good if ya on boost at the time eh!!!! could prove quite costly.
i'd stick to the bosch item as these use proper aeroquip fittings and are a much more reliable option!! yes they may be a bit more of a fuk on to fit... but it's definately worth it!!
PJ MOTORSPORT can supply you with a kit that includes the bosch pump and more importantly ALL of the aeroquip fittings and pipe required to do the job.......
ya'll need this little lot......
the difference in size to the original is err... fairly noticable!!! lol.......
if you opt for the bosch pump (which i would reccomend as it is definately the safest) then there are modifications which will need to be made to the tank sender/pump mounting unit.
this is how the tank unit should look when first removed from the tank......
the modifications are required due to the obvious difference in size.....
once the old pump is removed from the tank unit you should have something which looks like this.......
the bottom of the return pipe (on the lower half of the tank unit) has a bracket attached to it which the old pump sat on , this needs chopping off , but be sure to cut away as little of the pipe as possible.
looking closer at the top of the unit you can see the 2 pipes which are brazed into the unit , red = return to tank , white = feed from tank.......
the white pipe needs to be chopped off FLUSH with the unit on both sides.....
once chopped the hole needs to be enlarged to accomodate the aeroquip elbow union supplied with kit.
(note , the underside also has some protrusions which will need to be ground away to leave room for the aeroquip fittings of the new pump)
the aeroquip fittings supplied with the kit should be fitted to the new fuel hose as shown in pic.......
the blue elbow in the centre of the pic is what goes through the top of the tank unit where the original pipe was cut off flush
there should also be a silver coloured fitting (around 2" in length) supplied with kit , this is what screws on to the underside of the tank top , attached to the blue elbow... the new pump attaches to this silver fitting......
to give the pump further suppport it is advised that a jubilee clip is wrapped around the pump and the return pipe and tightened in place.....
be carefull when replacing the tank unit into the tank , as it will be a tighter fit due to the increase in pump size.
be sure to use a new fuel filter , the new pipework will screw into the standard ford filter no problem if an aeroquip fitting like this one is fitted to the filter......
hope this is of some use to ya fella!!!
oh yeah , i also used some nice new stainless steel tank brackets when replacing the tank!! ......
Old 01-02-2007, 08:02 PM
Mr.Ford
Mr.Ford's Avatar
L9KOS that's very good
Thnx!
Old 13-02-2007, 08:34 PM
AlexD
Post Miester !
AlexD's Avatar
Going to have a ago at this over the weekend, Well get the old fuel pump out,
thanks for the Pics and Tips..
Old 13-02-2007, 10:07 PM
PAT@SUPREMES
PAT@SUPREMES's Avatar
l9KOS : when u changed ur feul pump did u have 2 change the breather system.ive got a bosch 023 pump in the tank and have noticed i sometimes get back pressure when i remove the petrol cap but not all of the time.any ideas
Old 14-02-2007, 12:29 AM
adamski frst
adamski frst's Avatar
Location: brum/shropshire drives:- frst / escort cossie
very rarely happens to mine
Old 14-02-2007, 07:43 PM
PAT@SUPREMES
must just be my car
Old 15-02-2007, 07:54 AM
AlexD
Post Miester !
AlexD's Avatar
I get that sometimes in mine even now
Old 29-03-2007, 11:18 AM
Franco
Franco's Avatar
Dave, i couldnt find the rubber gasket ring anywhere on Microcat - even popped into Ford.........Still couldnt find it!
My tanks going back in on Saunday (same exact bits L9KOS used ) so i need to find it quick!!!!!!!!!!!
Thanks
Jase
Old 29-03-2007, 12:46 PM
Dave Henshall
it MIGHT come as part of the new locking ring,
alternatively, you could use a think bead of high modulus black silicone and let it go off before fitting the pump back in..
Old 29-03-2007, 12:59 PM
Franco
Franco's Avatar
Ahh never looked at the underside!
I'll sort something out Dave! Could i run a bead of gasket sealent round it??
Old 29-03-2007, 02:29 PM
Dave Henshall
i reckon so, as long as its not affected by petrol.
i know diesel fooks normal silicone sealant...
Old 29-03-2007, 02:33 PM
Franco
Franco's Avatar
It'll be all out again soon anyway no doubt!
Old 29-03-2007, 08:18 PM
Rolls
Rolls's Avatar
This will come in handy once i order my new pump and fitting kit
Old 29-03-2007, 09:25 PM
Kelv
Almost there!
Kelv's Avatar
never had any of this trouble,
all i do is open the tank in the boot to access the 044 fuel pump and swirl pot, and thru the bottom of the tank i can see all the fittings etc on top of the standard fuel tank/pump under the car.
just have to lift up the in boot tank and can have the under car fuel pump assembly out within minutes
Old 30-03-2007, 07:29 AM
Dave Henshall
you got a motorsport shell then...?
as these had a removable access panel in the boot floor.
Franco
Franco's Avatar
Who threw you a biscuit!!
Old 30-03-2007, 07:31 AM
Franco
Franco's Avatar
Ignore him Dave..........He ghey!!
(which means he had A1RS build all his lift pump, swirl pot in a custom box in the boot and a panle added to access the pump from the top......... I think! ).
Old 30-03-2007, 09:33 AM
Kelv
Almost there!
Kelv's Avatar
Franco only because you know
Coont
Old 30-03-2007, 12:03 PM
robbieg
robbieg's Avatar
Anyone know how much the PJ Motorsport fitting kits are??
Old 30-03-2007, 12:21 PM
AlexD
Post Miester !
AlexD's Avatar
I asked them,I think it was about Ł80 for all the bits and fittings etc..
I got mine form Mike R then went to a local motorsport outlet to get the
fittings.
Old 01-04-2007, 11:08 PM
G1EN
G1EN's Avatar
Have to do this on mine... as i think my pump has completly packed up.
How much is just the quip fittings and braided hose on its own???
Old 02-04-2007, 02:10 PM
Franco
Franco's Avatar
Just found the gasket finis for the sender ring.
6810424 Gasket - fuel tank sender.
no good to me now! Aint dropping it again!!
Old 02-04-2007, 03:30 PM
G1EN
G1EN's Avatar
Nice 1 Franco
Do Fords still stock the Filter?
Old 02-04-2007, 04:20 PM
Franco
Franco's Avatar
Get it from a Car spares Glen, they all do the same thing (not a pikey version though!).
Or have your pants pulled by Frauds!! Still in stock, think they're about 15+ quid
Old 02-04-2007, 05:13 PM
G1EN
G1EN's Avatar
I popped into fords in ilford on way home from work.. The gasket is something like 58p they didnt have the filters in stock, but available for order @ Ł28, which isnt too sad, plus you get the fancy ford box and receipt so all good in a way... im a bit finiky when it comes to reciepts, would rather a ford receipt than a car spares that no body knows of...
Im ordering a new bracket too, but they wernt readily available, but available from main warehouse, which takes a few days or so...
i will update with FINIS codes of all once i get them on the receipt 2moro.
Old 04-04-2007, 09:21 PM
G1EN
G1EN's Avatar
FINIS CODE
Fuel Filter: 5020405
Filter Brakcet: 6200560
TANK Strap bolts: 6470595 (for the bufty;s)
Old 04-04-2007, 09:24 PM
G1EN
G1EN's Avatar
L9KOS: How much did you pay for them quip fittings and hose?
Old 05-04-2007, 06:49 AM
Franco
Franco's Avatar
The robbing barstwards!!
Mine was 11 inc VAT...... And seeing as i change them yearly, glad i never went to fords!
Old 05-04-2007, 05:36 PM
L9KOS
L9KOS's Avatar
they came as part of the kit with the pump from PJ matey peeps!!
Old 10-04-2007, 03:03 PM
G1EN
G1EN's Avatar
I'll just use the original stuff then and look at getting this at a later date.
But need a little HELP now or advice.
i was contemplating on using my trolley jack with a peice of MDF on the top to cradle the TANK to drop it down. Will this be ok???
I will be making a few grooves in the MDF so its nice and stable on the Trolley Jack. But think i may get a helping hand to steady the tank while it comes down and put a few bricks underneath it either side...
Will this drop the tank down enough to gain access to the PUMP.
Old 10-04-2007, 03:26 PM
AlexD
Post Miester !
AlexD's Avatar
You will need to disconnect the fuel filler pipe and breather pipe.
I used a jack to steady the tank untill i had undone evertything.
I had to cut the jubilee clips off the filler pipe, as they were rusted on !.
Also watch the fuel lines as you lower it, there is not much play.
Old 10-04-2007, 09:34 PM
G1EN
G1EN's Avatar
Thanx Alex
Sounds so easy but so much could go wrong me is thinking.
Im going to attack this hopefully on saturday, i will try take photo's to ad this thread.
Old 11-04-2007, 12:01 PM
- Sim -
- Sim -'s Avatar
can anybody tell me the winding sizes and fitting sizes? As I need these fittings for my 023 pump setup .-)
thanks in advance
Quick Reply: Removing Fuel Tank & Fitting a New pump ???
