DIS ignition question - and a quick update with the car :)
Old 21-01-2007, 11:14 AM
Rolls
Rolls's Avatar
Default DIS ignition question - and a quick update with the car :)
Hi Guys, got a couple of quick questions on this, as i'm going to get on the phone and order it as soon as I get paid....
Where can i get a replacement dizzy cap from? - the flat ones without lead fittings?
Am I right in thinking that the best place to fit the coilpack is the original place where the boggo coil goes? - If so, what bracket to you all use, as I know that Zetec coilpacks are not flat at the bottom (and i'd assume thats whats used?)
AS soon as I get this sorted, the car will be having all of the breather system 'quiped (with the below) along the fitting of my 500 wideboy cooler, slim fans, turbo cooler, swirl pot, w/c pas tank, and quip fittings for all of this.... - I can wait to get started! - here is the lastest batch that arrived this week:
Rich
Old 21-01-2007, 12:33 PM
MONSTER
MONSTER's Avatar
Sorry cant help on your questions but would you mind sticking some pics of the i/c, rad & fans up please?
cheers
Old 21-01-2007, 07:08 PM
Rolls
Rolls's Avatar
certainly chap:
Old 21-01-2007, 07:20 PM
MONSTER
MONSTER's Avatar
Thanks mate, looks
Are you gonna have enough room for all that lot
Old 21-01-2007, 07:39 PM
adamski frst
adamski frst's Avatar
Location: brum/shropshire drives:- frst / escort cossie
rich got any close ups of the power res...
whats the 3 outlets for what size dash fittings etc as i am having one made thinking of having some dash fittings...
Old 21-01-2007, 07:50 PM
Rolls
Rolls's Avatar
Yeah mate - Its off of Daves car - and this is the best pic that I have (its obviosuly one from when he had it all on his car...) Soz, but thats the best i've got - the parts are all up in the loft untill I fit them...
There are 4 fittings on it - 2 to the PAS, and 2 for the watercooling
Water cooling are -6, PAS are -8 and a -10 i think...
Old 21-01-2007, 08:06 PM
adamski frst
ahh sweet, i don't wanna water cool mine so thats fine just need to know the actual dash sizes for the 2 and what length hose i need
Old 21-01-2007, 08:11 PM
Rolls
Rolls's Avatar
IF you can wait for a couple of weeks, then I can get you close up pic's of the bits that i've got, and measure the lenght of the hoses, and be certain the fittings are -8 and a -10.
Only thing that may trip you up is the metal PAS pipes, as i've got the quip fittings welded onto those too, for ultimate "tarty-ness" - (got those off of Dave too )
Old 21-01-2007, 08:16 PM
adamski frst
go for it mine aint a major rush its half done atm i will prob just have hose finishers for now, not as bufty as you
link to the GGR kit shows us a bit
http://www.grahamgoode.com/cosworth/images/ggr853.jpg
http://www.grahamgoode.com/cosworth/images/ggr852.jpg
Old 22-01-2007, 06:45 PM
Rolls
Rolls's Avatar
Anyone got any idea's on the dizzy cap?
Old 22-01-2007, 08:07 PM
PewteRS
PewteRS's Avatar
Zoo motorsport for the dizzy cap mate
I got my coilpack bracket off Lee @ fusion mate but you better ask Paul
Ripley first if its ok to use coz it was his original design.
Old 28-01-2007, 09:43 AM
Rolls
Rolls's Avatar
cheers for the info matey! - i'll have to make some call's methinks!
Also, here are the pic's of the PAS tank I promised- they are -8 and -10. the -6 in the corner is for the watercooling
Old 29-01-2007, 09:08 AM
Franco
Franco's Avatar
Old 01-02-2007, 02:24 PM
Dave Henshall
Dave Henshall's Avatar
Rolls,
i made up a small aly bracket (about half an hours job) and drilled, filled and cut it to accept the zetec coilpack and bolt onto the std coil moutning bolts...
Old 01-02-2007, 07:57 PM
Rolls
Rolls's Avatar
cheers for the pics!
Should hopefully be ordering all of the bits I need at the weekend!
Old 02-02-2007, 12:38 AM
adamski frst
will get mine done next week then
Old 04-02-2007, 10:10 PM
cossiemanden
DANISH cosworth abuser
cossiemanden's Avatar
Originally Posted by Dave Henshall
Rolls,
Where u got the leads from mate?
Old 05-02-2007, 07:52 AM
Dave Henshall
from stu at MSD as part of the coilpack conversion
Old 07-02-2007, 10:28 AM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
P8 (the Escort Cosworth ECU) is inherently DIS capable, and can easily and cheaply be switched into the DIS mode with NO changes of hardware, and the associated cost implications!
Leads:
http://www.randbmotorsport.co.uk/shop/Parts.asp?ID=6
Old 07-02-2007, 11:27 AM
Stu @ M Developments
PassionFords Creator
Stu @ M Developments's Avatar
Leads:
Inded it can, but rev counters are hardly free are they?
The Ford one wont work if its just software enabled so you do have both cost & hardware implications unless you use my driver which works fine with the std counter.
Old 08-02-2007, 03:14 PM
Damo V
Damo V's Avatar
As a side note........
.......I have a Pectel board dizzyless etc and managed to get a zetec escort rev counter to work perfectly in my car now!! Apparently sometimes this mod works sometimes it doesnt...
A.t.p
15-08-2015 11:37 AM
Gadget
Ford Escort RS Cosworth
13-08-2015 06:43 AM
Ben26
11-08-2015 04:19 PM
liam-rst
10-08-2015 08:46 AM
CabrioTurbo
01-08-2015 11:04 AM
Quick Reply: DIS ignition question - and a quick update with the car :)
