air con removal
air con removal
How easy is it to remove aircon stuff? The rad is off as Ive got a big intercooler on but its all the pipes to the bulk head and stuff where do they seperate?
just done mine mate,the pipes are a bit of a nightmare as mine wouldnt undo and ended up striping the threads,the pipes seam to come apart where you need them to the bulkhead one were a pain as there is a screw torxs head in the middle of the pipes if you got a screw driver type torxs bit your be ok but i had to remove the battery to get at it-three bolts holding the pump on are ok bit tight-the bracket bolted to the block that holds the pump was a cooount one bolt just in a funny position could only just get a spanner on it and no leaverage good luck
DixieTheKid
11
06-06-2020 11:20 AM
Fudgey
17-09-2015 01:06 PM
