Fual cap probs!!
Old 20-01-2007, 04:08 PM
Escos Jam
Escos Jam's Avatar
Default Fual cap probs!!
Hi all
Anyone ever had problems with there filler cap? Its the old style (non flap ones).
The key had been tight in it for a couple months now and when i removed it today it would not go back on. The key turns a wee bit but the white collar bit on the cap will not turn to the lock posistion. Iv tried WD40 and veriouse release oils but it feels more like a mechanical problem in the lock.
Can these caps still be bough from ford?
Any info much appreciated
Old 20-01-2007, 05:52 PM
cozzfather
C.R.E.A.M.
cozzfather's Avatar
a ford parts man told me you can strip them and clean them up.
its fiddely and a right pita but once mastered its easy,you could always
try giving it a real good wd40 and a smack to try to shock it.
the best thing to keep it maintained is good grease,as the wd dries up
eventually,hence the problem
Old 20-01-2007, 06:20 PM
Escos Jam
Escos Jam's Avatar
Cheers for that mate, is this quite a common prob with them?? Was gonna attempt to strip it earlier but really couldnt be arsed. Wil have a go at it tomorro.
Old 20-01-2007, 06:21 PM
rapidcossie
rapidcossie's Avatar
i had troule with mine a while ago Jam..
plenty WD and it should be cool
Old 20-01-2007, 06:29 PM
cozzfather
C.R.E.A.M.
cozzfather's Avatar
yep its a common fault with them if not greased, like i say if
regularly wd40'd it will be ok, but grease lasts a lot longer.
i have knackerd a few escort keys turning them too hard when
the thing has seized.
while you have the quality grease out its worth doing the door locks
and the boot,and the door hinges too
Old 20-01-2007, 06:38 PM
Escos Jam
Escos Jam's Avatar
Appreciate that cozz. Cheers
Old 20-01-2007, 06:39 PM
rapidcossie
i have spray grease if needed Jam
Old 20-01-2007, 06:51 PM
Escos Jam
Escos Jam's Avatar
Soond mate. If iv none in the van il giv you a shout tomorro.
Old 20-01-2007, 06:55 PM
rapidcossie
Old 20-01-2007, 07:27 PM
big-dirty-dog
big-dirty-dog's Avatar
yep,mine went a while back fitted a new barrel and chucked the old one away,cant remember how much it was
Old 20-01-2007, 07:31 PM
Mk5_XR3i_130
Mk5_XR3i_130's Avatar
how easy was it to swap barrel mate?
Old 20-01-2007, 07:32 PM
Escos Jam
Escos Jam's Avatar
Im assuming you got a different key etc when you bought the new barrel?
Old 20-01-2007, 07:36 PM
THE RADMAN
THE RADMAN's Avatar
you can get a barrel made up to your existing key easy to swap just a circlip to remove
Old 20-01-2007, 07:41 PM
Mk5_XR3i_130
cheeRS
Old 20-01-2007, 07:45 PM
Escos Jam
Escos Jam's Avatar
Maybe im soundin really stupid here rite, but do you just take your key into ford and they make a barrel to you key??
Old 20-01-2007, 07:55 PM
ossie cossie
ossie cossie's Avatar
I seem to remember bieng told from a while back that the keys can be read just by looking at them the degree of angle of the cut is gauged from one to four and it has a number of different cuts so if you look along the key you can read the key number something like 13452 i dont know how true this is. by the way i had the same problem with my fuel cap and i stripped it and greased it up all ok now.
Old 20-01-2007, 08:00 PM
Escos Jam
Escos Jam's Avatar
Think il just go down the strippin and greasin route. thanks for all the help guys
Old 20-01-2007, 11:46 PM
Dave Parker
Dave Parker's Avatar
copper grease seemd to work very well in these locks i found , ive also used fully synthetic engine oil makes them very smooth to operate
Old 21-01-2007, 02:07 AM
Arnie
Arnie's Avatar
My fuel cap problem is a lot more serious than yours, whenever I drive "enthusiastically" fuel will actually end up spilling out of the cap and all over the rear fender
Another mate of mine has the same problem, I'm assuming it's a common fault with large turbo fuel cap
Old 21-01-2007, 12:33 PM
lowman
lowman's Avatar
instead of using syntetic oil...you can also use ATF oil..automatic transmission fluid.that works perferctly.
Old 21-01-2007, 07:16 PM
cozzfather
C.R.E.A.M.
cozzfather's Avatar
yep you can if you know what your doing read ford keys from
approx 88 onwards, read it then go straight down the main dealer and
get one cut
with mk5 escort caps and van caps i found that some worked with any key,that got round the problem
of having a seperate key,i think it was putting the tumblers in a certain
sequence that did it
Old 22-01-2007, 08:51 PM
G1EN
G1EN's Avatar
ok, went through this palarva not so long ago..
done 2 keys with stiff cap.
So
went to fords, to get new cap (outside casing,where spring is), but after 3 caps order, not 1 of them was the same, despite the right FINIS No.
I managed to get a full set of locks off ebay for Ł40 with keys, so im in the process of changing all locks, but first i change the cap barrel, and use the new key (obviously) and its now fine.
So if you can get a full lock for as cheap as me, it may be the easiest option, plus you get nice new locks and keys.
hope this helps..
plus i wd40 my old one and did didley squat. so went for the whole new lock set.
Old 23-01-2007, 10:46 PM
S.Hannah
S.Hannah's Avatar
Hi All.
I just replaced the locks it was easier.
all still avalible from ford.
at around Ł65 well atleast falkirk ford dealer anyways.
Hope this helps.
Old 23-01-2007, 11:44 PM
S3an
S3an's Avatar
strip it and grease it, fook paying Ł65 for new ones when there is nothing wrong with it. so a new Ł65 set wont do the same eventually. i think so.
Old 24-01-2007, 12:22 PM
S.Hannah
S.Hannah's Avatar
thats ok if you havent knackered the barrel with all the prying.
eventually will just sieze up and thats a fookin nightmare beleive me.
The boot lock will be the next to sieze if its not already.
Been There.
But then you do get the added bonus of it taking another 10 years to get to the stage its at now.
Unless you grease it every year.
its got to be a better way.
new keys new locks cant get better than that.
Old 24-01-2007, 08:42 PM
Escos Jam
Escos Jam's Avatar
Originally Posted by S.Hannah
Hi All.
Hope this helps.
Did you replace all the locks mate? (2 doors, boot, fuel cap, ingniton).
I live in falkirk so it shouldnt be a problem to get new locks from them. Iv still to strip my existing fuel cap but it deffinatly feels more of a mechanical fault within it rather than just being tight.
Old 26-01-2007, 05:44 AM
S.Hannah
S.Hannah's Avatar
Yes m8.
i changed all them for new ones and it made a big difference
there was instantly no wear on the ignition and cap was like new trust me m8 it really is worth doing and all feel nice and tight when you use them.
you even get the bonus of having all original ford keys which kinda adds
to the apperance of the vehicle.
pm me if you want to get in contact ill send you my details
we can have a chat or even meet up if you want
Old 28-01-2007, 03:49 PM
Escos Jam
Escos Jam's Avatar
Yes m8.
pm sent
Old 12-02-2007, 03:38 PM
Rturner
Rturner's Avatar
but what do you do if the key does not turn the barrel? like mine is!
Old 12-02-2007, 07:38 PM
S.Hannah
S.Hannah's Avatar
You have to use loads of WD-40.
or better still WURTH 2040 release oil is the buisness.
you might need a pair of vice grips depending on how tight it is.
and just work back and forward for what seems like an eternity use plenty of release oil when working it will clean out the rust mostly
using firm pressure it will eventually start to go free then kinda force it a little more and you should get it free. it usually takes ages.
you can also spray it in the hole and leave it for a couple hours and repeat the process until you get results.
Hope this helps m8.
Old 12-02-2007, 08:36 PM
Rturner
Rturner's Avatar
the problem was it was not stiff but the teeth had worn so i need a new barrel
Old 12-02-2007, 09:31 PM
S.Hannah
S.Hannah's Avatar
you may need to go with the vice grips m8.
tug and turn (if possible)
Old 14-02-2007, 09:13 AM
german tony
german tony's Avatar
My cap got so knackered I actually filled the car up & then couldn't get the key out of the cap again. So there I was, standing on the forecourt like an idiot, fortunately an idiot that had, by chance, got his spare keys with him.
Moral, grease 'em people.
I got a new barrel for my existing cap, cost way less that 65 quid though.
& they fitted it for me.
Old 14-02-2007, 07:35 PM
Escos Jam
Escos Jam's Avatar
Iv ended up buyin a new lock barel from ford for 20 odd quid.
Unfortunatly i had to build the lock to my key which took a good hour of fannyin about. Got there in the end and am well chuffed now. Put a bit grease in there once it was built and it workin perfect.
One prob tho ... i lost the wee circlip that holds the barel to the cap I'll have a look in the stores at work for one tomorro
Old 15-02-2007, 03:16 PM
Mk5_XR3i_130
i got a circlip here pm me your address and i'll post it
Old 16-02-2007, 08:04 PM
Escos Jam
Escos Jam's Avatar
Your a gentleman and thanks for the offer but i managed to find one at work
Thanks again
Old 16-02-2007, 09:02 PM
AndyShep
AndyShep's Avatar
hey mate i was,nt so fortunate the cap would not come off in the forecourt so no fuel no fun.ended up giving it the tretment with a screwdriver dont suppose you know where i would get another and white would be handy.l
Old 23-02-2007, 02:30 PM
The DIVA
The DIVA's Avatar
Andy...
Have you damaged the fuel cap itself ?...i build all my own and keep loads of bits at home,so if you get stuck give me a shout...
Old 24-02-2007, 07:42 PM
AndyShep
AndyShep's Avatar
diva the fuel cap is knackered,the barrel is shot to bits the only thing i have left is white suround.only had the car 6 or 7 hrs the fuel cap was the first problem then to cap it off the engine let go.
Old 24-02-2007, 09:14 PM
The DIVA
The DIVA's Avatar
You have PM...
Quick Reply: Fual cap probs!!
