side lights
side lights
just had car going tried my side lights and they wont come on checked fuse and also tested to see if power there nothing my main and full work but side dont so rear and front side lights and fogs and clock lights dont come on has any one else had problem if so what is problem is the fuse box goosed thaks for any help nats
1 Post
more than likely the switch in the stalk that does the indicators/sidelights etc, very common for them to fook up on the sidelight switch.
you can either get a new complete stalk set from ford for around 70 quid,
or do what i did, get some frmo a breakers for a fiver, then unsolder the old stalk and solder the new one in its place,,
see the fooked burnt wiring on my old ones
