Rod bearings for farndon crank with smaller journals
I've a 88mm farndon crank + carillos (130mm)
My problem is, that it's quite impossible to get new bearing shells!
-> nr. on the old bearing S803SA STD TB they are made by AE
the crank journals are 49mm, rod diameter: 52mm and the old bearing is 20,4mm wide
please help me to get new bearings! To know the engine were the shells were originally used, would be the best!
thx
thx
