| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Ford Escort RS Cosworth This forum is for discussion of all things pertaining to the Ford Escort Rs Cosworth. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
#2 |
More boost Igor!
1. Connect, or charge up your flat battery.
2. Start your car, do not touch or use the throttle. Leave to idle for 3 minutes. 3. Now hold the revs at 1200 rpm for 2 minutes. 4. Now drive your car for at least 5 minutes, at different speeds. |
#3 | |
Trader Score: (0)
Rep Power: 13 ![]() |
Quote:
the P8 reset procedure is a bit more involved
__________________
![]() Thank fcuk for ugly women all the boilers bags and trolls, just so they could get a shag they invented alcohol. |
#4 |
More boost Igor!
Ah.
Is the P8 procedure any similar to the L6/L8, and what did I miss out?
#5 |
Trader Score: (0)
didn't know there was one for the L6 or L8 as they don't have any KAM like the P8...
__________________
#6 |
More boost Igor!
I can't believe I'm actually learning something on the internet!!
Didn't realise that... So how do you re-educate a P8?
#7 |
Trader Score: (0)
taken fron the GGR website
![]() The engine management system on the Large Turbo Escort has what is known as ‘adaptive learning’. This in simple terms means that the engine management system will make changes to the fuelling of the engine, based on the information it receives from many engine sensors. Earlier models of the Cosworth had an adjustment screw to allow fine-tuning of the fuel mixture. The Escort Cosworth does not have this facility; the engine management system will make these adjustments itself. Over a period, the management system ‘learns’ where the fuelling isn’t correct, and applies a richening or leaning off adjustment to the fuelling at the relevant points in the fuel map. Unfortunately, many additional factors can affect the fuel mixture readings, and this can sometimes cause the management system to make an incorrect adjustment. If the adjustments made by the management system are too severe, the fuel mixture reading will fall outside of the operating range of the HEGO or Lambda sensor. If this situation occurs, the management system will be unable to readjust the mixture correctly. In this case, it will be necessary to re set the engine management system memory, and allow it to ‘re- learn’ the running strategies. To re set the memory, you must carefully follow the following procedure (with the engine stopped and at normal operating temperature): 1) Locate the memory re set plug inside the engine compartment and remove the red cover (if fitted). On right hand drive vehicles this can be found between the battery and front suspension top mounting. There are three diagnostic plugs here, (see photo), the circular plug is the memory-reset plug. (On some models, this shape of plug is used to alter the ignition timing for different octane fuel). 2) Prepare three pieces of wire to connect the three connections of this plug together. DO NOT CONNECT TO THE PLUG YET. 3) You will need help to complete this part of the operation. Turn on the ignition, as if to start the engine. (Operate any immobilisation systems etc.) DO NOT START THE ENGINE. You will hear the idle stabiliser valve click slowly (about once per second). As soon as the ignition is switched on, (but not before), connect your three pieces of wire to the plug sockets to inter-connect all three terminals. This must be done quickly, after the ignition is turned on, but before the fuel pump stops priming the engine. After about seven seconds, the idle stabiliser will stop clicking. After a further twenty or thirty seconds, the idle stabiliser will click extremely quickly, then return to clicking once per second. When this happens it signifies that the management system Kept Alive Memory is erased. Turn off the ignition, and remove your wires from the sockets. Re fit the red plug cover and return the diagnostic plugs to their original position. Do not worry if this doesn’t happen first time, you may find it necessary to carry out the erasure procedure at least twice until the operation completes as described. 4) The management system now has to re learn its idle and slow running strategies. Allow the engine to idle for three minutes, then increase the speed to 1200 RPM and hold for two further minutes. The engine management system should complete its learning strategy after approximately 5 miles of varied driving.
__________________
#8 |
Is there not some sort of tool from the likes of gunstons that you can get to do this - I remebr when I had the FRST engine in my XR2, I bought a Gunstons fault finder, and you couldf use it to reset the ecu also
#9 |
Trader Score: (0)
you can buy a sub loom from ford that does the job
very ecpensive for what it is though, about 12 quid for basically 3 x 3" lengths of wire connected to gether to a male end that fits in the socket on the car.. i have the finis cose in my hotmail account - but cant log on at the moment
__________________
#10 |
ohy, really- i'll have a lookski on microcat when i get home... - I guess the finis may be in the esc. supplement of he workshop manual any how?
#11 |
Trader Score: (0)
nope
__________________
#12 |
Trader Score: (0)
FINIS code for sub loom : 6155682
__________________
#13 |
old post but is this the right proceedure?
#14 |
__________________
Sierra saphire 88 2wd Cosworth stg1 Escort Cosworth 93 stg3 |
#15 |
My car cuts out at 4000rpm (MSD chip/map 3bar/Siemens 55).
I've made a diag and I found a default code 44 on my car. I've tried this to reset it, but the car still cut at 4000rpm. I heard well the idle valve clicking more quickly, and I though it was good...
__________________
#16 |
Unplug the iscv and lambda and try it,often two badguys that causes the car in limp home mode at 4k
#17 |
Code 44 = EEROM ERROR
EEROM is an integrated part of the Motorola processor and is used to store some data. That means a replacement ecu. |
#18 | |
Quote:
just tryd this on my escos p8 and the pump primes up breifly then the valve just clicks fast all the time????? ideas!!!!!!!
__________________
#19 |
go onto escortrscosworth.com the guys on there will tell you
#20 |
Have done this resting sometimes, never been a problem whit that
__________________
#21 |
PassionFords Creator
![]() ![]() ![]() Trader Score: (12)
Rep Power: 36 ![]() ![]() |
__________________
Best Regards, Stu . Click here to read my tuning articles. . Click here to visit our Brand NEW webshop. Find us on FaceBook. |
| Display Modes | |
