Small turbo cam cover machining
Does anyone know someone who can machine my small turbo cam cover for a cam sensor,or someone who could provide a drawing??Regards Robbie
Surely if the Hall Effect sensor was compatable with P8 managment people would use that instead of going through the trouble of machining camshaft and cam cover and purchasing all parts required?
aka Turbosailorboy
Jaycos is definately using one with his DTA P8 Pro
If a Hall Effect sensor isn't compatible with the ecu then I'd look at using a modified Cosworth distributor for it's phase sensor (it's a variable reluctance sensor).
Matt Baxter
16-09-2015 08:30 PM
JoeyBoyden
18-08-2015 10:52 PM
