ECU info
ECU info
hello i have just removed the cover off my escos big turbo ECU and i have found some extra chips inside can any one help me with identifying them for me. That is to say what they are where they are from and what they do? many thanks
I live in austrailia and the car has been here from new and the chips may have been installed way back then, also is there anyone you guys or girls know that could help me out on this post.
So what do these do? i bought the car and the seller said it was 340HP is that right, it also has a 3inch de cat exhaust and blue injectors, and a 3 bar map sensor.
I only have the standard boost gauge and that is in bar. Does mountune have a web site ? or e mail address? yes light blues. i am new to escos tuning and need the info.
Testing the future
basically, the chip on the right is the eprom that contains the program that the ecu runs to make the engine run, including the fuel and ignition maps, corrections etc.
those eproms are very cheap to buy and cheap and easy to copy. so after a while of various tuners modifying the contents of the original eprom as programmed by ford, there were many copies being sold cheap as chips. obviously the tuners that done the original hard work didn't like this, as they usually didn't see a penny from those sales.
that's where pectel came in. they reverse engineered the software, and then encrypted it before programming the eprom. that meant that if you were to put that chip into a standard ecu, it would not run properly. it needs to be plugged into a pectel board to unencrpyt the program from the chip to the ecu. that meant that you had to buy from a tuner to get the matched board and chip which kept them in business.
it also meant that tuners had to buy software from pectel to be able to connect to the ecu and alter the maps to tune to different specs.
hope that helps with the mystery a little.
what it will not tell you is anything about the maps on the chip that you should know so that you know what fuel to run, how much boost you can use etc. but as yours are clearly marked up, you should be able to find all of that out from the original supplier
very good explanation just what i wanted to know. thank you very much, i have sent an e mail to mountune and am waitimg on more info from them.
She ,s in bits at the moment fitting up a 500 cooler and changing out some broken electrical multi conectors. in the engine bay will be back on the road soon.
