Extended offside front driveshaft
Almost there!
Why you thinking of one of those Paul?
surely your not running the camber that will warrant having one, and your car certainly isnt overly low either!
tried sourcing an xr4x4 item?
kelv are you still running 3.9 diffs? How much did that cost to do, and whats the difference in acceleration and top speed like?
I'm running an xr 4x4 shaft off side in mine, but it makes a right racket on ful lock, im on -30 konis and "18 rondells I broke a standard shaft on STD power , only lightly launching as well
inner bearing, the joint sheared and jammed against the x-member- I put it down to having a bit of right lock on as I was turning across a busy duel carridgeway and needed a swift get away, didn't launch hard just had about 3000rpm and slipped the clutch to get it on boost- is a T25 BTW
hey paul ive got xr4x4 drivers side drive shaft in mine mate never had a problem with mine. Lost my orignal one on full lock hiting a hole in the ground
Originally Posted by Kelv
Originally Posted by Dan
Would an XR 4x4 one stand up to Paul's power?
You found one yet Paul?
Originally Posted by justin.e
Paul,
why do you need one?unless your going over two degrees neg on the front I dont see a need..
Seems to me like your running out of things to buy, and have started clutching at straws!
Also the only problem mention by Mark @ Grove was lunching them off the line on full lock (which I'd imagine aint ever gonna happen!) and if you did then you fooking mental & thoroughly deserve it!
surprised no one has said about the engine mounts yet just changed mine and the passenger side one just fell to bits when loosened off. my drivers side shaft popped out in september, but the drivers side mount was spot on is this normally the case(its the opposite side mount that is fubarred.)
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
