245/35 x 19
245/35 x 19
what do i have to do to get this size tyre on an escos i will also be fitting 8.5 x 19 wheels with ET 28 will i also need spacers any help please.
Yes you will need spacers, upto 18mm, but at least 10mm. The tyres would fit on those rims, but the ideal size would be a 225/35/19.
If you want to go wider, then a 245/30/19 would be more favourable than the tractor sized 245/35.
Depends on how low the car is too.
Good luck. Oh and if you want 245/30's they are £220 each at the moment
tkrath
Ford Escort RS Cosworth
21-05-2004 08:59 PM
