Wirng question
Monte Geek
Wirng question
When my autoelectrician unravelled the wiring loom that runs along the bulk head.. by the alloy brake distributer block on the left hand side under battery there was a single wire (brown with red stripe) with a black connector on it with a male spade. Can't see what it would plug into and its quite short so doesn't reach much.. diagnostic port? or something else?
not for centre console guage, mine was as nightdavva said, inside the car, its for some sort of switched earth as its the same type/colour as the a pillar door pin switches..
Monte Geek
Well everything works so I'm just going to wrap it back up into the loom
EDIT quite thought is there a light or any type of switch in the glove box?
1 Post
lookin at the pic again..... the other end (which i though that was) is near the fuse box, when you dro it down its there - but for no apparent purpose- just taped to the loom ..?..?
1 Post
maybe...? or a spare wire thats from the normal escort loom cary-over..?
or maybe somthing for the Air con, as it goes near the intake for the blower - maybe to switch from fresh air to recirc..?
